Riddles...
- General Chat
- Riddles...
Riddles...
03-02-2016 9:31 AM
What is a word made up of 4 letters, yet is also made up of 3. Sometimes is written with 9 letters, and then with 4. Rarely consists of 6, and never is written with 5.
2. Without a calculator work out the following:
Start with 1000
add 40
add 1000
add 30
another 1000
add 20
yet another 1000
and, finally, 10
What is the result?
Forum Moderator and Customer
Re: Riddles...
03-02-2016 10:10 AM
the wording is rather ambiguous,
I read it as add them so the answer is 2100, however it could just as easily be interpreted to be 100 /
Re: Riddles...
03-02-2016 10:16 AM
try this disambiguation:
Start with1000
add 40
add 1000
add 30
add another 1000
add 20
add yet another 1000
and, finally, add 10
Re: Riddles...
03-02-2016 10:25 AM
ahh see the starting word is take which implies your starting with a negative,
however that disambiguation does simplify it down to a result of 4100
which isn't a riddle but a straightforward sum, btw I rather suspect the answer was supposed to be 100
Re: Riddles...
03-02-2016 12:23 PM
Quote from: w23 @nano
Start with1000
A have amended my OP.
Re: Riddles...
03-02-2016 12:35 PM
2. 2090 As some of the steps do not say to add.
Re: Riddles...
03-02-2016 4:39 PM
as would some /sum fit the riddle and I suspect a few other candidates, context is everything, what only fits if you allow the use of deviations from the dictionary to present as the answer
Re: Riddles...
03-02-2016 4:56 PM
Is that another riddle?
Re: Riddles...
03-02-2016 5:45 PM
(This is an easy one!)
Re: Riddles...
03-02-2016 6:13 PM
( I don't think that's the answer you were expecting.)
What can go up a chimney down but can't go down a chimney up? (Easy again).
Re: Riddles...
03-02-2016 6:29 PM
Quote from: w23 ( I don't think that's the answer you were expecting.)
Nope, but close enough...
Re: Riddles...
03-02-2016 9:24 PM
Quote from: w23 A chamois leather
Towel
Umbrella
'If One costs £1, and two costs £3, and 25 costs £2 , what am I buying?'.
Re: Riddles...
04-02-2016 2:36 PM
Quote from: doris 'If One costs £1, and two costs £3, and 25 costs £2 , what am I buying?'.
Should the question be 'If 1 costs £1, and two costs £3, and 25 costs £2 , what am I buying?' ? If not I give up.
Re: Riddles...
04-02-2016 10:03 PM
Re: Riddles...
04-02-2016 10:08 PM
Customer and Forum Moderator. Windows 10 Firefox 84.0.2 (64-bit)
