Replacement of outdated services.
Fixes: 186
I was reading this post and my immediate thought was 'why not'.
Recently our entire area has had gas, water and electricity supply replacements, requiring digging up streets and laying heavy pipes and cables at a considerable cost.
Why shouldn't the fourth service, namely BT Openreach be also required to maintain their cabling and equipment to a reasonable enough specification.
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
Fixes: 12
Re: Replacement of outdated services.
because gas, water and electricity are basic human rights?
but having a telephone line isn't?
Isn't it said now that you are underprivileged/poor/deprived if you don't have access to a PC/broadband/mobile?
Fixes: 71
It could be that some of those services use items are 'lifed' with replacement included in costs. However the life of telephone cables is regarded as 'until it becomes too costly to patch up'.
David
Fixes: 12
Quote from: billnotben
by whom ?
Fixes: 186
Quote from: chenks76
I would suggest that access to drinkable water is a basic human right.
The rest are 'desirable' services.
Fixes: 12
heat isn't a basic human right?
Fixes: 186
No, I see it in the 'desirable' category and it can be provided in a multitude of ways, many of which are not classed as services.
However my topic wasn't intended to be discussing the Human Rights Act Wink
Fixes: 12
well i only mention it due to, IMO, water, gas, electricity services being basic services that everyone is entitled to.
whereas a telephone line isn't, IMO.
Fixes: 62
So why doesn't my village have gas and how do I make them provide it
nanotm
once you have the service (any utility service) you pay a standing charge (or line rental for the phone) which theoretically works out as the money to replace your bit of the service every 25 years .....
Fixes: 22
There's probably an increased risk of gas or water leaks as the pipes get older, which would be dangerous and/or a waste of gas or water.
nanotm
similarly there are conductivity problems and stretching with older wires in phone and electric supply systems (not so with fibre optics) so replacing things on a rolling pre planned maintenance basis is the smart thing to do, for some unfathomable reason all the utility companies stopped performing these functions shortly after privatisation (including national grid, hence the problems with pylon lines) which lead to many successive operating fines on several companies most notably thames water and severn trent...... Ofwat being the toothless apologist of a regulator that it is however fails more than it succeeds at ensuring ancient leakage systems are replaced or repaired and current losses are estimated to be around 3.4billion litres a day (give or take half a billion) there was a nice long article in the guardian about it back in 2012 http://www.theguardian.com/commentisfree/2012/may/08/water-industry-pipes-scandal
the gas mains aren't any better and again leaky systems are often only replaced when something goes wrong (like a fire ....)
Fixes: 12
Quote from: Oldjim
because you have electricity.
if you didn't have that then you'd have gas.
one or the other as a basic right, not both.
Fixes: 186
I know of a couple who bought a house then paid to have the gas supply removed, right back to the street before they would move in.
