Renaming the Vacuum Cleaner
- General Chat
- Renaming the Vacuum Cleaner
22-05-2008 8:17 AM
However she has, quite correctly pointed out that the device does NOT clean vacuums and therefore the name is misleading.
Maybe someone can suggest a more appropriate and accurate name for this device.
Sorry for posing such a taxing question at such an early hour
Customer and Forum Moderator.
Re: Renaming the Vacuum Cleaner
22-05-2008 8:21 AM
cant be Dyson, he has moved production abroad
The industrial ones are normally "Henry"
22-05-2008 8:22 AM
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
22-05-2008 8:44 AM
I don't want to replace one generic name with another or others and there is the issue of Intellectual Property Rights.
@adiewoo
Good try but it's not quite specific enough to dispel doubts if you see what I mean.
22-05-2008 8:46 AM
Insect
Removal
Tool
22-05-2008 9:17 AM
22-05-2008 9:20 AM
22-05-2008 9:43 AM
Device for the removal of dust by means of vacuum suction and a long hose.
Terry P would be very happy.
22-05-2008 10:07 AM
3Mb FTTC
22-05-2008 11:23 AM
A pressure cooker does not cook pressure.
A feather duster is not for dusting feathers.
I see no problem with using the term vacuum cleaner. I do have a problem with using one though but that's just because I'm a single bloke with a love of sitting around doing nothing.
22-05-2008 11:29 AM
Of course the other classic in this case is most homes have 'central heating' and on the walls are 'radiators' ... those 'radiators' are not ... they are convecting though.
SW.
3Mb FTTC
22-05-2008 11:31 AM
Quote from: Strat She insists on calling the vacuum cleaner a Hoover.
Clearly the word Hoover is a brand name rather than a type/class of device or product.
So what brand of product is it ... tell her if she wants to be really accurate, she will have to call it a Panasonic or Electrolux or whateve brand it really is.
SW.
3Mb FTTC
22-05-2008 11:55 AM
22-05-2008 11:56 AM
Quote Tell her its a Goblin
I cant see whats wrong with that, cause mines always a gobbling up the dirt
22-05-2008 12:07 PM
Quote from: Jameseh Gloria.
Do you really want to be confused with hoover?
