Remote Control
Remote Control
This is a useful app for the iphone Smiley Smiley  Very Clever Cool
Remote Control
itsme
Re: Remote Control
And you believed it?  Grin
Re: Remote Control
@artmo, very clever, should have been a man driving! There are so many more things I need a mobile phone for before a parking app
a) mobile Phone app for a TV remote? b) Open a tight fitting Jar, app c) put the wheeley bin out app d) iRon a shirt, e) replace a light bulb, e) find the car keys
Fixes: 12
Re: Remote Control
I could think of many apps..
Unlock / lock the shed (additional hardware required for the shed lock mechanism)
Household lighting controls (handy if you're away - you could setup a random light changing pattern)
Heating controls
Car start in the morning and heat up
Unlock the front door instead of needing keys
Lots of other uses too if I could even afford one  Roll eyes
pierre_pierre
Re: Remote Control
well it was a demo at the Frankfurt  Motor show, it does exist  http://www.valeo.com/index.php?id=1191
Re: Remote Control
As listed on the right of the video Cool
Check it out itsme Wink
itsme
Re: Remote Control
Currently are there any park assist systems that control gearbox, clutch, brake and accelerator?
pierre_pierre
Re: Remote Control
Ford Focus, nearly but not quite
Feb 2011    http://www.techdigest.tv/2011/02/ford_focus.html
itsme
Re: Remote Control
The Focus is the same as others I have seen, the system only control the steering the driver still has to do the gears, brakes and accelerator.
Re: Remote Control
Does it remember to close the car windows?  Didn't seem to on the video.
Now Zen, but a +Net residue.
Re: Remote Control
Maybe you need another app for that Smiley
Fixes: 60
Re: Remote Control
It's an IPhone app, it doesn't work with Windows Grin
Fixes: 238
Re: Remote Control
Quote from: AlaricAdair
I assume you'd have to press the Start button for that anyway Cheesy
Forum Moderator and Customer
Re: Remote Control
That could be a pane Wink
pierre_pierre
Re: Remote Control
re what can remote control do?
its a bit of a Drone, but it can bomb Pakistan dodgy camps
