Reminicing again
Reminicing again
I was trying to explain how much simpler things were in my childhood to my granddaughter the other day. Do you remember a give-away toy that was issued with comics such as Beano and Dandy. I think it was called a Whizz Bang?? it consisted of a piece of card folded to form a long triangle, inside was another fold of brown-paper glued to the card.
When flicked sharply the brown paper would open out with a loud "bang" We used to have great fun creeping up behind our contemporaries giving them a fright. Something to do with the brown paper opening out at exceeding the speed of sound.
Granddaughter, retired to her room and computer looking slightly bemused.
Fixes: 101
Re: Reminicing again
I remember those.
Customer and Forum Moderator.
Used to make my own, piece of paper, just two folds (and no 'apps' to install).
Also remember taking a large blade of grass holding it between my thumbs and blowing through it (kind of a rasping/bussing 'whistle') - or a comb and greaseproof paper for a 'harmonica'.
Call me 'w23'
randpwar
Tracing paper wrapped around a comb then blown, anyone?
I used to collect lots of those sort of things back then. Just found this in the bottom of an old box in my cupboard.
beeceegee
Quote from: Strat
I remember those.
+1
Quote from: randpwar
+1
Quote from: w23
+1 (though better with a privet leaf)
Fixes: 101
Never thought of a privet leaf...found a decent blade of grass to suffice.
I offered my wife a comb and paper instrument but she couldn't handle it as it tickled too much....forerunner of the Kazoo.
What about simple things like going out with your friends and saying "I'll be back for tea" and getting a smile and a wave.
No questions, no contact, just "out".
Fixes: 101
Or going down the road to a local shop without a key as you didn't need to lock your door because next door neighbours were watching who came up the passage.
I fancy getting a whip and top just to see if I can still do it.
198kHz
All Star
Fixes: 10
Quote from: Petlew
Yes, I remember those.
My favourite 'bang maker' was the metal 'bomb', comprising two parts with a percussion cap between them, held together with a rubber band. I see there's an updated version available on Amazon. Note that the packaging states "SHOULD BE USED UNDER ADULT SUPERVISION".  Roll eyes
I seem to remember creating some decent bangs with a leaf - elm possibly? One made a circle with thumb and forefinger, then pushed the centre of the leaf through, such that the edges of the leaf still covered the circle. Then the flat palm of the other hand was slammed hard against the circle, rupturing the leaf and creating (sometimes) a bang.
Remember you are unique - just like everyone else
Scoobydoo's, mostly by the girls, although I remember a few boys doing them as well; four or six lengths of thin plastic line folded and linked over itself to form a long square or octagon of multi-coloured blocks. I've actually seen one of these recently on my school coach.
Fixes: 101
Ah...cap bombs. Kids these days would require it to contain a C4 charge.
Marbles played in the road-side gutter. It was mostly safe to do so then.
Quote from: Strat
Had to make our own, a couple of short 1/2" bolts and a nut and a load of the red bits scraped off some Swan Vestas matches!
Call me 'w23'
Across the road cricket with the wickets chalked on the walls, we used to play two innings test matches over several days like that.
Very occasional car would interrupt play. More often than not a driver would stop so a ball (tennis) could be bowled.
