Redefined Words
Redefined Words
An interesting list of definitions:
1. Cashtration (n.): The act of buying a house, which renders the subject financially impotent for an indefinite period of time.
2. Intaxicaton: Euphoria at getting a tax refund, which lasts until you realize it was your money to start with.
3. Reintarnation: Coming back to life as a hillbilly.
4. Bozone (n.): The substance surrounding stupid people that stops bright ideas from penetrating. The Bozone layer, unfortunately, shows little sign of breaking down in the near future.
5. Giraffiti: Vandalism spray-painted very, very high.
6. Sarchasm: The gulf between the author of sarcastic wit and the person who doesn't get it.
7. Inoculatte: To take coffee intravenously when you are running late.
8. Osteopornosis: A degenerate disease. (This one got extra credit.)
9. Karmageddon: It's like, when everybody is sending off all these really bad
vibes, right? And then, like, the Earth explodes and it’s like, a serious bummer.
10. Decafalon (n.): The gruelling event of getting through the day consuming only things that are good for you.
11. Glibido: All talk and no action.
12. Dopeler Effect: The tendency of stupid ideas to seem smarter when they come at you rapidly.
13. Arachnoleptic Fit (n.): The frantic dance performed just after you've accidentally walked through a spider web.
14. Beelzebug (n.): Satan in the form of a mosquito, that gets into your bedroom at three in the morning and cannot be cast out.
15. Caterpallor (n.): The color you turn after finding half a worm in the fruit you're eating.
Fixes: 173
Re: Redefined Words
Some excellent words and definitions there artmo...thanks Smiley
Customer and Forum Moderator. Windows 10 Firefox 63.0.3 (64-bit)
Re: Redefined Words
They're brilliant. Especially like Sarchasam, As a great lover of sarcasm I know exactly where that is coming from.
