Red Lorry, Yellow Lorry ? No, Blue Lorry
Infinity
Should have gone to Specsavers !
dletter
Re: Red Lorry, Yellow Lorry ? No, Blue Lorry
He must have being going some, measured on Google Earth that bridge covers approx' 140 feet of road. Shocked
For those interested it is here: http://goo.gl/maps/FF03m
Looking at that I can't help thinking illegal immigrants shaken not stirred.
TORPC
he was likely to be following the iMaps app on his idevice  Lips are sealed
That's odd, because the clearance height is marked at 15`. When you factor in a bit of tolerance usually 3", he should have fitted under. Unless hee is labelled as a high vehicle that is.
Fixes: 142
Do you think he may have been reversing as he missed a right-hand turn and went up the kerb?
Forum Moderator and Customer
He probably through he could drive over the McD's Burger container not realising it contain a half brick.
Now Zen, but a +Net residue.
