Reckon it's time for a newun?
Luzern
Fixes: 9
I've berm looking round for what could be damaging my broadband experience, and am a little suspicious of the door bell/chime transformer. This was installed by the previous owners, who moved in to the then new-build in 1971, so it could be from fifteen years upward ( we moved in in 2002) years old. The man was a known bodger, and examining the transformer unit, I found one wire coming loose, and other doubtfuls. It had worked before, so I'd not needed to llok closely.
I'm willing to buy either a transformer compatible with the chimer, or fit a new wireless kit, but there is no rectified voltage detail on the transformer for compatibility Roll_eyes
At its age, probably over twenty, and with my predecessor's skill, are my suspicions at all valid? What do you think.
Pic of item
14 REPLIES 14
Steve
Seasoned Pro
Re: Reckon it's time for a newun?
So when the door goes it ruins your broadband experience? don't blame you it would ruin mine too Cheesy
If life gives you lemons, make lemonade.
Luzern
Fixes: 9
As far as poss, I leave my live-in domestic, and bed warmer to respond!Funny
(Memorandum: hide this post from the beloved wife!
Steve
Seasoned Pro
Just do away with it completely. If it is someone or even something important they can knock louder and longer.
twocvbloke
doorbell-broken-joke-300x201
twocvbloke
Silliness aside, looking at the transformer, it's not discoloured as though it had overheated, and the electrical noise that it may have caused on your broadband might just have been the loose wire arcing slightly (creating AM radio noise), trim the ends of the mains side off, re-strip them and refit them and it'll probably work fine again, wirewound transformers are tough things to kill... Smiley
As for finding out what is needed to replace it, well, most doorbell transformers have multiple taps, so you can choose 8v, 12v or 24v (they're all AC, no rectified voltage here, just stepped-down 50Hz AC), if 8v doesn't work, move up to 12, etc., if the transformer still powers up but you still want to replace it, just test the output voltage with a multimeter set to AC volts (usually marked as "V~") in a 3-digit range and it'll tell you what voltage it's putting out... Smiley
Luzern
Fixes: 9
@twocvbloke thanks for that. There is some yellowing on the centre front area, not picked up in the pic. If I decide to keep the ends will be trimmed, but even allowing for prev. owner's bodges, there're  no gaps to feed wires through. No makers nor model is on the transformer or the chime; just a made in China label. Odd! Sorry for the ignorant misuse of rectified.
Alex
Fixes: 12
Well that is a monster. I suppose you can always disconnect it.
My dad fitted a wireless doorbell to my place years ago and it works fine. Only thing is the receiver takes some weird battery (is not a watch one, it's like a AAA but half the size). All you need to do is to attach the doorbell to the wall of your property.
VileReynard
Fixes: 19
Nothing wrong with using a battery.
Alex
Fixes: 12
Yep, but it is a weird one.
Not a common one you usually see. I had to go into a hardware shop and ask.
The assistant did find it but had trouble herself, it's one with about five different codes.
Luckily I had the old card with the code, as I would never been able to tell anyone what battery it was, short of unscrewing the thing off my wall Smiley
Browni
Aspiring Hero
Fixes: 52
One of these by any chance?
Ex-Plusnetter now living life in the G,fast lane!
Luzern
Fixes: 9
I took a trip to the very local Screwfix. (Usually places like that are miles away.) I bought one of these . It'll be a big job to install it, as getting it out of packaging is considered part!Funny
Alex
Fixes: 12
I know everyone is really excited Tongue
One of these:
twocvbloke
Cor, talk about tension waiting to find that out, you should start a TV show about it!! Funny
(sorry, just poking fun at the false-tension competitive shows on TV where they play a sting of music every other word to make things feel more tense than they actually are!!)
Alex
Fixes: 12
Yes I felt like doing a reality TV Big Brother/I'm a Celebrity esque impression, and saying "The battery is ...."
*waits for a few hours before giving the answer* Grin
