Rear Number Plate Lights
- General Chat
- Rear Number Plate Lights
25-01-2015 4:04 PM
we have no light on the front number plate..... so why do we need them on the rear?
In " the olden days" when number plates were black with white or silver letters/numbers... I can see the point... but is it just a "legacy" left over requirement on the m.o.t. test, because someone hasn`t yet realised number plates are reflective and do not need to be illuminated at night .
( yeah, ok... so if it was a dark street, and someone got knocked down, any witnesses won`t be able to read the number plate... but there again... how many "witnessses" actually thought about getting the number of the car involved ? ? ? ) "sorry, it all happened so fast,.... I didn`t think about that.... "
Re: Rear Number Plate Lights
25-01-2015 4:11 PM
25-01-2015 4:43 PM
25-01-2015 4:50 PM
25-01-2015 4:52 PM
25-01-2015 4:59 PM
25-01-2015 5:02 PM
25-01-2015 5:21 PM
Exactly my point.... and you agree with me.... a reflective plate shows up when you shine a light on it... so why do you need to illuminate it? as mentioned in the original post... front plates are not illuminated ...
If a lawman saw a car that was doing something illegal, he would probably be in a law car,... with ....... YEAH!... HEAD LIGHTS... so when he is driving behind it... he will have his headlights on....and be able to read the number plate... even if the car was stationary and did not have any lights on,in the dark, he can still shine his torch on to read the number plate... and... surprise surprise, if the car was parked, in a dark place ....it would not need to have its number plate illuminated... and ... of course... during the day.. it is not needed to be illuminated.... ipso facto... number plate illumination is superfluous to requirements, and therefore the m.o.t. law should be changed in the same way as for allowing the use of reflective number plates, when they changed over from the black/slliver/white type.
do you see?
25-01-2015 5:27 PM
25-01-2015 5:30 PM
Quote from: shutter do you see?
Yes I see, I see you're obviously being intentionally obtuse here...
It doesn't matter if a cop is in a car or on the street or in bed with your wife, if they don't see your plate on your car lit up, then your car is an MOT fail and illegal to use on the road and will be fined for driving without proper illumination. End of.
Yes, if the cop shines a torch on a parked car's plate, the retroreflective properties would light it up, but if the car's speeding by and there's no time to grab a torch, then the plate illumination, which is a legal requirement in case you've not picked that bit up, is the bit that helps the cop see it as it goes by, and even if they're in a car, say parked up in a lay-by with the headlights not aimed at the plate in question, the cops can see the plate, type it into their onboard computer and pull up their details before the ANPR gets to see it.
Therefore, having the plate self-illuminated from a bulb on the car is a requirement, regardless of it's reflectivity, you're just trying to make up an excuse to not to change the bulb on your car...
25-01-2015 5:56 PM
I raise that question because...... there is no need for it to be illuminated anymore.... because ? ? ? ? ?
I am well aware that it is a requirement of the m.o.t. test.... but in light of the two previous lines...... it should no longer be a requirement.....
do you see ? ? ? ? ? ? ?
25-01-2015 6:04 PM
Quote from: twocvbloke It's the law, simple as that, you could fight it with logic like that, but considering the laws of the land were written by people who often had no sense of reality anyway
And on that line of thought I'd like to bring forward another point...
We often moan that those in power have no sense of reality, they're all out of touch, don't understand the real world etc.. yet many of them got in through sheer luck, aren't qualified in anything much and are only kept there cos we voted them in. In other words some of em are just like you and me.. and we moan that they are out of touch
Anyhow with regards to the number plates i've nevever understood why the front plates didn't have to be lit up. It doesn't make a lot of sense although to a point, i suppose if a car is making a speedy escape, the plate you'll see longest is the rear one.
With regards to the speed cameras being blinded by the reflection of a number plate there is truth in it. You can buy a special spray to spray over your number plate and it creates a super bright reflection on the number plate that blinds the camera. I used to think it was a myth but my old neighbour (whos country of origin won't be mentioned here for fear of racism accusations despite it being his country of origin) had used it on his rear number plate and when we came down the road at night, all you would see was the reflection of our own cars headlights - no letters or numbers. A closer inspection of the plate showed quite clearly where he had sprayed the stuff on.
25-01-2015 6:08 PM
and as I pointed out, and you also state... it is not illuminated...
25-01-2015 6:10 PM
25-01-2015 6:11 PM
