Re: charges to mobiles over 1" long
ian007jen
over 1" long
Is this one second, one minute or one hour.
Second I presume
Ian
Infinity
Seasoned Pro
1" long is one inch long !
ckcomputing
The standard abbreviation for 1 minute is 1' and the standard abbreviation for 1 second is 1"
The standard abbreviation for 1 foot is 1' and the standard abbreviation for 1 inch is 1"
So take your pick!!  Cheesy  Cheesy
Professionals are predictable - it's the amateurs that are dangerous!
ckcomputing
So, it's probably a one inch long second!!  Wink
Infinity
Seasoned Pro
So, the longer the ", the longer the " ?
and...
Quote from: sb1
can someone easily explain to me how calls to mobiles which are over 1" long are charged.
my mobile is 4"x1¾" does that make it 7" ?
but it's only ½" thick
So, calls to my mobile are longer than 1"
pierre_pierre
my mobile is bigger than 1 inch
but I do have a small videos that might squeeze in
Fixes: 62
Split off and moved to Chit Chat
Fixes: 188
What about degrees, minutes and seconds of arc Tongue
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
I'll show mine, if you'll show me your's... Cool
Fixes: 21
I think you are going off on a tangenet there, strat  Cheesy
Fixes: 188
To a degree...yes Sad
198kHz
Aspiring Champion
Fixes: 13
A sine of agreement then, Strat? Assuming I've got the right angle on this.
Remember you are unique - just like everyone else
JayG
This thread seems rather theoretical, if not actually hypotenusical, and there is no way I'm anywhere near adjacent (in fact, quite the opposite) to cosine-ing up for it.
Fixes: 188
A little obtuse if you ask me Lips are sealed
Fixes: 251
It won't be long before this threads starts going round in circles  Grin
It's kind of acute idea Cool
Forum Moderator and Customer
