Re: Kbps or KBps?
VileReynard
Seasoned Pro
Fixes: 9
Re: Kbps or KBps?
Actually, it's totally meaningless how many bits the channel is rated at - or should that be 8M-baud  Cheesy
All I care about is the number of data bytes I get - a bit is a useless entity.
Fixes: 9
Re: Kbps or KBps?
The Baud rate would add even more confusion IMHO.  The days when Baud and bit were synonymous have gone,
M
James
Re: Kbps or KBps?
I think it would add a bit more confusion.
Re: Kbps or KBps?
Personally, I'm waiting for an opportunity to use the word 'yobibit' - there's just something satisfyingly zany about it.
Fixes: 61
Re: Kbps or KBps?
I suspect you are going to have a long wait - but if you really want to wait just think what you could do with yobibyte
Fixes: 9
Re: Kbps or KBps?
Let me out!  Let me out!    We'll soon be heading into Shannon and Information Entropy and all that mathematical stuff I've almost forgotten Crazy
M
Re: Kbps or KBps?
Last time I used bauds was when working with telex at 50 Baud ! - and I could do complex trigonometry, J operators and all that  !
itsme
Re: Kbps or KBps?
Quote from: Crucibleofevil
8Mbps is 1MBps but 8M Baud will be 800KBps (0.8MBps) so you will get less.  Wink
Fixes: 9
Re: Kbps or KBps?
Ye Gods - what have I started? Shocked
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 127
Re: Kbps or KBps?
Well what else did you expect round here? Roll eyes
Will Moderate For Thanks
pierre_pierre
Re: Kbps or KBps?
if you lot arnt care full ASBO will be back with company and show you what a bite is
VileReynard
Seasoned Pro
Fixes: 9
Re: Kbps or KBps?
Quote from: itsme
Does the use of the B indicate Byte or Baud? Grin Grin Grin
Fixes: 51
Re: Kbps or KBps?
It might be a bit of a squeeze pushing parallel data down a serial telephone wire Roll eyes
Customer and Forum Moderator.
scootie
Re: Kbps or KBps?
bite hell no. am that confused with this thread now am chasing my own tail round now  Grin
pierre_pierre
Re: Kbps or KBps?
Dont Worry Asbo, no one has mention the other query is K=1000 or is K=1024  Roll eyes Roll eyes runs away again
