Rapport problems.
onlyme
Rapport problems.
Has anyone else had problems with Rapport, programs running slow and websites hanging?  I can't find a thread on this subject; has it been covered already?
nadger
Re: Rapport problems.
http://community.plus.net/forum/index.php/topic,93874.0.html
Not had any running problems personally
Nope! my Rapport is running fine.
Yes, as per above-mentioned link, my friend had the same problems, as have many others according to my searches.
The Rapport site has instructions on how to remove it.  Would suggest that you use Revo uninstaller if this is what you want to do in order to get rid of it properly.  Not sure if you will need to switch it off first.
Rapport is running fine for me, no worries
I've avoided it so far, but....
Has anyone used it where they access MULTIPLE web sites (e.g. different banks) all of which want you to use it - any issues?
nadger
I bank with HSBC and SWMBO with Barclays and I access both these sites without any problems.
Fixes: 18
Nope..... No problems here ... been using it for a week or so now. Smiley
alanf
I use Rapport for multiple banks and have had no problems using Firefox 3.6/Windows 7.
