Questions and answers:
petlew
There are a lot of well read and knowledgeable members on these forums, no doubt bursting to share all that useless information they've had bottled up for years
A number of daily newspapers run a Q&A column, and at least one radio station devotes a weekly 1 hour slot to much the same thing.
I'm mildly surprised that it hasn't been tried in this forum before. Or maybe it has and I've missed it.
Questions must be morally clean, motoring questions banned, NO Google (or other search engine) link answers allowed.
So just to start things off:
Q. how are artificial sponges made?
5 REPLIES 5
7up
Fixes: 14
Re: Questions and answers:
With a machine Tongue
petlew
I suppose I should have expected that
shutter
Fixes: 47
Arti fishously of course
nozzer
By allowing urethanes to polymerise (you can look up the reaction yourself!) in a mould of a suitable shape (car seat cushion, bath sponge, etc) and at the same time either bubbling CO2 through the liquid while it cures, or heating it up to boiling point so that it vaporises. Both will make a sponge, the latter a rigid one, otherwise known as foam insulation. Foam spray cans contain CO2 under pressure which comes out of solution to make bubbles, and they are usually rigid because of the specific urethane chemicals used in the reaction.
So there! Smiley
2u2me
Don`t know, but the Romans knew how to make use of the natural one`sThumbs_Up
