Question about TalkTalk Fibre
Can anyone tell me if a fibre user on TalkTalk (a.k.a Tiscali) needs a Username / Password in order to connect to the Internet?
2 REPLIES 2
MattyC
Champion
Fixes: 46
Re: Question about TalkTalk Fibre
Not certain, but a search on Twitter makes it seem like it's likely.
Thanks for that @MattyC, I did think that was the case, and that means as I suspected his router is not configured correctly which might explain his crappy speed.
