Pump toothpaste dispensers
Fixes: 142
Is it just me or does anyone else have a problem once it has dispensed around 1/3 to 1/2 of it's contents?
It then seems that the only way to get the remainder is to use the brush to push on the bottom while pressing firmly on the pump. As soon as the paste appears it is a matter as getting the brush back to the top before it disappears down the plughole Cheesy
Forum Moderator and Customer
Fixes: 13
Re: Pump toothpaste dispensers
That reminds me of Colmans Mustard..... apparently, one of the directors said, that the more people left on their plates, after a meal, the more profit Colmans make.....  Cheesy
Quote from: Mav
That's probably why the 99p shops are full of them.
I did try one and as you say half way down it runs out of steam. I find I have to pump it a couple of times to get it to work now.
itsme
Used Colgate's pumps for years and did not experience this problem. Have reverted back to tubes as they are cheaper.
Fixes: 9
Has anyone tried using something like http://www.amazon.co.uk/Tube-Squeezer-Toothpaste-Cream-ect/dp/B003B7RLKQ ?
Does it get the last bit out of the tube?
Does anyone know where you can get a better designed version?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
alanf
I've never had a problem with Sensodyne ones.
itsme
Have to say when I used to use the pump dispensers I was amazed how well they worked. Sides of the tube perfectly clean and only could get one may be two more brush fulls usinf the method describe in the OP.
Maybe Mav's using stripey toothpaste, if one of the stripes gets a knot it will probably jam the pump mechanism  Cheesy
Call me 'w23'
Fixes: 142
Quote from: alanf
Strange as it's the Sensodyne ones I was talking about.
Quote from: walker23
I'd hope you'd get some sort of signal before any problems Cheesy
Infinity
I buy these in 10's when on offer at Boots 2-4-1's and half price.
(Free delivery to store when ordered in-store.  Offers seen on website)
Just checked, the standard ones are on offer at 52p each !!!
http://www.boots.com/en/Aquafresh-Fresh-Minty-Toothpaste-100ml_867527/
Never had a problem with the pump version.
As for squeezing out the last drop from a squeezy tube, I find my thumb and forefinger does an excellent job !
Tube folded then pushed in-line.
(With a crocodile clip on the "folded" end as the tube gets over half empty )
Quote from: PlusComUK
Remember when you used to do that with the old toothpaste tubes. The last bit used to come out with grey stains from the metal. Sad
Oh I thought the one's valet was responsible for putting the toothpaste on one's toothbrush.
Now Zen, but a +Net residue.
Fixes: 9
Grin Grin Grin
Excellent!
pierre_pierre
I use the maid, much better looking
Infinity
Note to self ...
Put electric toothbrush in mouth before switching on !
