Protecting Sat-Nav
Fixes: 61
Protecting Sat-Nav
I have bought a Garmin 2598 and in the manual it says....
This product contains a lithium-ion battery. To prevent the
possibility of personal injury or product damage caused by
battery exposure to extreme heat, store the device out of direct
sunlight.
Undecided
It sits in the windscreen for goodness sake, often in direct sunlight.
Should I buy a sun-shade for it or maybe a 70 factor sunscreen Roll eyes
Customer and Forum Moderator.
Fixes: 171
Re: Protecting Sat-Nav
Ah, but is it left in the windscreen when not in use? The key-word being 'stored' Wink
Forum Moderator and Customer
Wrap it in aluminium foil to protect from sunlight
Now Zen, but a +Net residue.
nanotm
get a copper impregnated screen blind for it then you protect it from harmful EMF at the same time as keeping it out of direct sunlight  Wink
Fixes: 61
Do you think if I put it in the glove box and ask her to speak up that will work Undecided
When I use mine I place it on the seat beside me. When I don't need it I put it in the glove box.
Fixes: 61
I like mine on the windscreen where I can glance at it without too much distraction.
The instructions that came with mine include a brief anti-theft guide which includes removing the mount and cleaning the screen.
It also advises against storing it in the glove box.
I wonder why they can't be stored in the glove box Undecided
I don't use the screen on my sat nav. I rely on the voice instructions.
Fixes: 61
Possibly because glove boxes generally aren't locked.
I like visual confirmation like for example when there are 2 left turns close to each other.
The glove box will be the first thing searched for valuables in the case of a break in. Most people keep their phones / MP3 players / satnavs in the glovebox.
Fixes: 16
Quote from: Strat
Don`t be daft, Strat...... she won`t be able to see where you are going, or recognise the area you are in... so any route instructions will be completely useless...  Cheesy
Fixes: 171
There are times when I wish I could put SWMBO in the glove box  Grin
Since passing her test she is becoming ever more critical of my driving questioning many actions; did you indicate, look out for that car, mind the kerb... - she seems to forget I taught her everything she knows Wink
Fixes: 61
@shutter  Grin Grin
Quote from: DomS
?..or on the dash with the windows down while the family are feeding in McDonalds as I saw in the carpark yesterday.
Fixes: 10
With the number of you that have smart phones i wonder why any of you still use satnavs?
My partner is the same, has s smart phone with a sat nav app on it but she's always taking my tomtom with her. To think.. it was actually a present from her to me.. i see why she got it now lol  Roll eyes
Fixes: 171
I'm happy to use my Smartphone as a Sat-Nav but SWMBO had to have a proper one Roll eyes
