Private browsing
Fixes: 9
Private browsing
Firefox has a private browsing tab but what does this actually do ?
Does it offer you any sort of protection over and above what your firewall/ antivirus offer ?
pberry
Re: Private browsing
Nothing to do with shielding you from dodgy sites (that's usually built into the browser), it means your browsing session doesn't leave any trace on your computer, ie no history, cache, form details, etc.
http://en.wikipedia.org/wiki/Porn_mode
That's interesting.  I didn't know that.  Thanks for the info.
Fixes: 173
Chrome has an 'Incognito Window' option which does much the same thing.
Customer and Forum Moderator. Windows 10 Firefox 63.0.3 (64-bit)
Steve
Seasoned Pro
And It sounds much better than " porn mode " Tongue
If life gives you lemons, make lemonade.
Fixes: 62
Interesting question - does "porn" mode also remove flash cookies. I suspect not as they bypass the browser
Steve
Seasoned Pro
Many sites that use Flash, (BBC iPlayer included) make use of Flash Stored objects which sit outside the control (for now at least, and as I understand it) a browser’s private history mode. I’m guessing it also sits outside the scope of a browser’s ‘clear cookies’ and ‘clear history’ actions?
If you’re intrigued about what flash ‘cookies’ you might have set on your computer, you can inspect them (and delete them) using this Adobe tool:
http://www.macromedia.com/support/documentation/en/flashplayer/help/settings_manager07.html
Fixes: 62
Better still - use Firefox with this addon https://addons.mozilla.org/en-US/firefox/addon/6623/
Steve
Seasoned Pro
Show Off Tongue
Quote from: Oldjim
Yes, that's a great addon Jim.  Installed some time ago when you first mentioned it.
