Private Messages
Private Messages
When using PM's, I can't see how to reply to a PM?
Mayfly
Re: Private Messages
When reading an email in the inbox I have a purpley/pink reply button bottom right, just the same as there is in a thread post.
Emmm! interesting that, as I know of at least one other member who was having the same trouble.
But, yes you're quite right Mayfly.
I wonder why the reply button wasn't available yesterday?
Ah! I see where the confusion lays. If the PM is fairly short - say less than three lines - the entire message can be shown in the message list without opening it. Therefore the reply button doesn't show.
Doh!!
Fixes: 62
Snap - I had the same problem Embarrassed
And reported it here but can't be bothered to look it up
It seems to me that in most other message windows where a message continues/overflows the window size there is a "more..." link on the bottom right. This usually opens the full message window, and in this case would include the reply button.
I would be helpful here too.
