Prisoner dilemma
- General Chat
- Prisoner dilemma
Prisoner dilemma
Prisoner dilemma
08-02-2013 11:17 AM
You are allowed to ask ONE question to identify the door which leads to freedom. You may put your question to either of the guards, bearing in mind that you don't know which one will tell the truth.
Forum Moderator and Customer
Re: Prisoner dilemma
08-02-2013 11:59 AM
"Could the guard with the door to freedom please open the door?"
Either that or "Can I have a Big Mac and Fries please?" lol
08-02-2013 12:22 PM
Then pick the opposite door
08-02-2013 12:40 PM
08-02-2013 12:44 PM
Quote from: picbits "Which door would the other guard say led to certain death ?"
I think you are on the right lines but surely you would have to ask both guards a question
08-02-2013 12:51 PM
If you asked the guard who always told the truth, you'd get a correct answer - the other guard would lie about which door led to certain death so you'd pick the opposite door.
If you asked the guard who never told the truth, he'd lie about the answer the truthful guard would give hence needing to choose the opposite door again.
08-02-2013 12:54 PM
08-02-2013 1:02 PM
08-02-2013 2:51 PM
Customer and Forum Moderator.
08-02-2013 3:18 PM
Quote from: picbits You don't need to ....
Yes you do. If you don't know which guard lies then how do you know to pick the opposite door? Likewise if you don't know which guard tells the truth.
08-02-2013 3:28 PM
You would pick one of the two guards at random, ask them which door the other guard would say would lead to certain death then pick the door that wasn't mentioned.
door a = death
door b = life
truthful guard would say lying guard would say door b
lying guard would say the truthful guard would say b
so pick the door mentioned and you'd be safe.
08-02-2013 3:46 PM
Ultimately, which door to pick depends on the question asked:
If you ask which door the other guard would say leads to certain death, you pick the door he say.
If you ask which door the other guard would say leads to safety, you pick the other door.
You're effectively getting both guards answer with a single question, and as the true answer is negated by the lie (true & false == false), your guaranteed the answer is always a lie.
08-02-2013 5:22 PM
Through the first door he sees himself being waited upon by a Marilyn Monroe.
He rather like that place, but as he has a choice he chooses to have a peek through the second door he sees himself being waited upon by the same Marilyn Monroe.
He asked why it was the same scene, how can it represents heaven and the “the other place”.
The first door shows the scene of Karl Marx being rewarded.
The second door shows Marilyn Monroe being punished.
(change names to suit audience)
Mind you might have been Groucho! not Karl!
08-02-2013 5:42 PM
Okay, this time imagine you're on a game show, and the host gives you the choice of three doors: behind one door is a car, behind the other two are goats. You pick a door, but the host, who knows what's behind the doors, decides to mess with your mind. He opens one of the other doors, deliberately revealing a goat. He then asks you if you want to stick with your choice or switch. Which do you do, stick, switch, or doesn't it matter?
Answer
08-02-2013 7:25 PM
