Prepayment meters
Fixes: 9
Prepayment meters
I was not aware that if you got into debt for whatever reason the energy companies could force you to have a prepayment meter, even in private property they can get a court order and the Police can force their way into the property for a meter to be fitted.
Luzern
All Star
Re: Prepayment meters
and the meters won't necessarily get the delinquent out of debt, unless they are timely adjusted to current tarries, and readings are timely.
Fixes: 188
It took a relative of mine 3 years to get rid of prepayment meters from her council flat.
The previous tenants fell into serious arrears with the quarterly billing so when they disappeared without trace the council arranged for prepayment meters to be fitted.
Because of the previous history of the property energy suppliers refused to change the meters.
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
Fixes: 12
Quote from: gleneagles
It's been that way for over 25 years. I should know, my parent had one done when i was a kid. Not a nice experience living with one of those ****ing things. They also go wrong too. I had one moons ago at a place i moved into and it kept cutting off my supply prematurely. The leccy board eventually agreed under duress to replace it with a normal one and investigate the PP meter for faults. They eventually admitted that they had found it to be faulty and credited me £50 for the hassle.
VileReynard
All Star
Fixes: 11
They are evil things.
We had a prepayment gas meter for many years, until the council installed gas central heating.
Had to keep it well fed with half-crowns. (That's 12.5p pieces to you youngsters).
Then we had a proper meter fitted in the redundant coalhouse.
