Power drill replacement recommendation
- General Chat
- Power drill replacement recommendation
25-08-2014 6:39 AM
A general purpose drill, cordless would be nice, not sure I understand the difference between NiMH and Lithium-ion.
Any recommendations, (rather like the look and feel of the DeWalt DC-100)..
Re: Power drill replacement recommendation
25-08-2014 7:34 AM
I have a cordless PowerLine Hammer drill (PHD144-28) 14.4V, Ni-CAD, which I purchased as a general purpose drill
For very general use, it is very good & doesn't miss a beat
That said
The only downside I have encountered
Is even with the best quality bits, it struggles to drill through brick
For drilling into brick / chasing walls etc I have got a
MACAlister MRH24 24V NiCd 1.7Ah (SDS)
Which I tend be using more @ the moment
Not sure a cordless would last 30 years though The units might, however I (suspect the batteries won't)
I also have for site work
(BLUE) RYOBI Impact Drill Driver (CDD-1801) & Drill Driver (CD1-1810)
All the above comes with two batteries, in their own blow-moulded case(s) for easy transportation / storage
25-08-2014 8:50 AM
DeWalt are overpriced because of the name but are good , if you want one to use everyday for you employment you need to go for a good name brand , the old saying you get what you pay for
My self i used to fit kitchens , i found Hitachi to be a good make and Good price for what you get
25-08-2014 10:00 AM
It all depends on what you want/need in terms of a drill. This is a good price for a basic household drill -
http://www.screwfix.com/p/hitachi-dv18dsfl-jc-18v-1-5ah-li-lon-cordless-combi-drill/43195#
25-08-2014 10:01 AM
Hitachi are a good make, Bosch industrial are ok.
Used to work in tool repair for several years & we where a DeWalt warranty repair centre, wouldnt have a DeWalt if it was given to me.
We where also a Ryobi warranty centre, the older machines where good, the newer stuff was throw away.
If it was my money i'd go for a Hitachi.
For light / general low useage in DIY just go for a cheapie from the local DIY centre.
As for the Wolf, they where a good make back in the day.
25-08-2014 10:08 AM
25-08-2014 10:10 AM
Quote from: PowerLee <snip>
<snip>
That said you can use the newer (Green) Lithium RYOBI batteries & Charger with the older machines, just as I do
Plus RYOBI make a vast range of machines the can be used with the same batteries, IE: Planer, Circular saw etc
Not used the (Green) RYOBI machines (thus can not comment on the quality)
25-08-2014 10:14 AM
Lost count of the amount of Makita machines we saw there where beyond economic repair due to new part's incompatibility.
Hitachi when they modify thing's always make sure the new part is backwards compatible.
25-08-2014 10:16 AM
how frequently you would use it - batteries tend to discharge over time
do you always use it within reach of a power point using a normal extension lead - could a mains powered one do the job
would you want to use it for an extended period - may need two batteries - not cheap at all
what type of chuck do you want - one which takes a normal drill bit or one that needs hex head bits, Note that large diameter masonry bits seem to only come with normal reduced diameter (12mm) shanks
would you ever want to use it for heavy duty use - example drilling a largish diameter hole through a wall or drilling through steel - where a battery powered one may be down on torque
25-08-2014 10:23 AM
25-08-2014 10:25 AM
25-08-2014 10:33 AM
Quote from: Oldjim The other and perhaps more fundamental questions are
I would like to add
When using any corded device
Make sure you use an RCD (they are inexpensive & can prove invaluable)
@PowerLee
It depends how they are used / abused / chucked in the van or stored correctly
I have had mine for several years, & have always looked after them, by keeping them in their supplied blow-moulded case & They have had a lot of heavy duty usage over the years
I have seen many a trades(person) just chuck theirs in the back of their van(s) without care, then they have a cheek to call then rubbish when they break
Like everything
If you look after them / it etc, then they / it, will look after you
25-08-2014 10:35 AM
I've begun to buy some Festool tools for my woodworking workshop and I'm going to upgrade my drill with one or two from the Festool range - they are pricey, but the best out there imo.
25-08-2014 10:52 AM
Quote from: TORPC I would like to add
I only use one of those when using it outside and then I use an RCD protected power point
I wouldn't have thought it was necessary indoors as otherwise other hand held devices would need them (hair dryer for example)
25-08-2014 11:07 AM
They said they had been through a few makes and models and settled on the Makita..don't know the model.
I bought a Makita Kit from B&Q on special offer but without the bit set...no great loss as I have loads of drill bits.
It has 2 batteries but only one has been used so far as it never seems to run out of charge.
Customer and Forum Moderator. Windows 10 Firefox 84.0.2 (64-bit)
