Poundland creator to create online store.
3 REPLIES 3
Re: Poundland creator to create online store.
anything with a minimum spend I avoid tbh as that in my eyes I class it as a potential scam
I sometimes go to the pound shops and typically spend less than £5 so why would I spend minimum of £23 online ??
Most families round here dont spend more than £10 a week in the pound shops unless its the give more money to rich firms season(s) and lets be poorer and waste electric on useless lights that are not designed to be used all year round and typically gets used for 1 season then either tossed in the garbage, gathers dust in the loft or garage or put on sites like freecycle
Edit:
Just a cotton pickin minute
I didn't spot this earlier
That's like 23 items that will need to be packed shipped by RM or courier that 1 will have to wait in for and may not be all shipped in 1 carton or shipment
That also need to be taking into consideration
Good advertising for Warburg Pincus and a possible IPO.
Fixes: 21
I had a voucher for £2 off a £12 spend in £Land. I just binned it. The max I spend is usually less than £7. Although saying that I ONCE spent £23 in one in Edinburgh (£World) - as it had a lot of different stuff compared to the local competitor.
