Post Office Track and Trace problem
Fixes: 409
Just tried to track a recorded delivery posted yesterday but the Track and Trace page constantly refreshes.
I have tried FF, Chrome and IE all with the same result.
Anyone else seeing this?
Forum Moderator and Customer
6 REPLIES 6
Re: Post Office Track and Trace problem
Using Pale Moon 12.3.
Yes it keeps bouncing up and down as it keeps refreshing.
This is where I usually start from. Seems ok.
https://www.royalmail.com/track-your-item
Fixes: 409
Thanks for checking.
Hopefully it'll be sorted by the morning.
Edit: Thanks for the link and my package has been delivered.
Seems to be OK now Mav.
Fixes: 409
Yes - it does, thanks.
I know I could have waited till today but I wanted to know whether it was specific to my connection or not.
What I have noticed is that the page appears to load without the search field, etc then instantly refreshes and it appears.
Seasoned Pro
From your original link Mav the address first loads with WWW. at the start then swaps to WWW2.
If life gives you lemons, make lemonade.
Fixes: 409
Not too sure what the difference between www and www2 two is but the link I supplied in my OP was direct from www.postoffice.co.uk.
