Please can someone check my blog for video ALL IS WELL>>>> SEEMS TO BE WORKING
Fixes: 21
http://nemosphotography.blogspot.co.uk/
Please scroll down the blog, and see if there is a video shown at the end, of me sending on a morse key.
When I check my blogs  ( should be a video at the end of each one that is about morse key)... all I can see is a white square, where the video should be.
I have checked "preview" after uploading a "new version", and the preview shows the  video and it works. but does not appear ( white square only) when I have "updated" the blog
All previous blopg video positions show a white square,...
Any comments/advice please.
Just a thought.... am running Ghostrey.... but it has never blocked my videos before...  any setting I should be looking at here  ? ? ?
pwatson
Re: Please can someone check my blog for video
Fine for me with Chrome, IE and Edge on a Windows 10 machine
Fixes: 21
Ok Thanks.....
Anyone else ?
Fixes: 188
Works fine for me in Waterfox and Microsoft Edge on W10
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
beeceegee
Works in Firefox (43.0b1) on Win 10 - took a few attempts as the player kept crashing. I think Firefox gets a bit hysterical with its Flash plugin and throws a wobbly.
Fixes: 21
OK... Thanks guys..... Using FF41.02... there is an update to 42.0 tht I should do.... also using Ghostery so maybe something there is blocking MY view of the video... any suggestions  ?
Work OK for me with an old version of Pale Moon.
Fixes: 21
Ok.... Thanks to everyone....  seems the update to FF42.0 has sorted the problem... I can now see and hear the vids
Much appreciate you help guys.
Wink
