Pineal Gland
Steve
Seasoned Pro
Pineal Gland
Was doing some research on this and came across some really dark stuff like It being a 3rd eye and once you open It all sort of nasty things could happen to you. How true do you think that Is? Not a lot Is known about the gland and some say Its locked way way In our brain for a reason.
The secretory activity of the pineal gland is only partially understood. Its location deep in the brain suggested to philosophers throughout history that it possesses particular importance. This combination led to its being regarded as a "mystery" gland with mystical, metaphysical, and occult theories surrounding its perceived functions.
Numerous spiritual philosophies contain the notion of an inner Third Eye that is related to the Ajna chakra and also the pineal gland, and to which is attributed significance in mystical awakening or enlightenment, clairvoyant perception, and higher states of consciousness. This idea occurs historically in ancient central and east Asia, and also in contemporary occult theories relating to yoga, Theosophy, Pagan religions, and New Age spiritual philosophies. There is no clinical evidence to support these assertions.
http://en.wikipedia.org/wiki/Pineal_gland
If life gives you lemons, make lemonade.
1 REPLY
Re: Pineal Gland
you know that box you keep in the garage?  the one with all the screws, nuts, bolts, bits of wire and stuff?  the brain needs such a box and that is the pineal gland.  Wink
edit: added smiley
