Picture/Photo size.
Pete11
Seasoned Pro
Fixes: 4
Picture/Photo size.
Sorry if this is in the wrong place, please move to proper place if need be.
I was wondering what the picture/photo size is to post one in the forums. I have done a search for answers to this question, but found nothing. Or do I need to make a certain number of posts to do this? I remember being a member of another forum to do with fishing and had to have a minimum of 50 posts to reach 'Trusted' before pics could be posted. Thanks for any answers.Wink
A float tip is pleasing in its appearance and even more pleasing in its disappearance.
Growing old is inevitable...But growing up is optional.
18 REPLIES 18
shutter
Fixes: 47
Re: Picture/Photo size.
When you make a "new post"... underneath the text box, is the word "Browse".... below that is  "File attachment limits"  and it says...
Maximum files per post: 9
Maximum size per file: 5.2MB
Accepted filetypes: jpg,gif,png,jpeg,pdf,csv,txt
Someone somewhere, has changed the action of the "browse" from multi- use... to "single use"... so if you want to add 9 pics, you have to "post" the original, then "Edit" it after it appears on the forum board, 8 separate times to get your full quota of 9 pics attached.
I did make a post about this inefficiency on the Community Site board
https://community.plus.net/t5/Community-Site-Feedback/Adding-pics-to-a-post-Not-working-properly/m-p...
But it seems to have died a death, as nowt has been done about re-instating the multi-use .... Cry
Pete11
Seasoned Pro
Fixes: 4
Thanks for that, it'll only be 1 pic...2 at most in 1 post, don't want to take up space on servers. It's the size I was wondering about, in pixels, like avatars are 80x80.
Oldjim
Fixes: 62
But if you wish to post an image then you don't use that link but the Insert a Photo on the top bar and then you can easily add multiple images
The use of Browse is not the recommended way
As far as I know the limit is 5MB per image and a maximum of 10 images per post
There isn't a specific size (in pixels) but when rendered on the page it is sized accordingly
Pete11
Seasoned Pro
Fixes: 4
Ok, thanks a lot Thumbs_Up Now I have an idea on size. Thanks for replies all/each.
MKSlinky
Seasoned Pro
Quick tip.., if for some reason your photo is blocked i.e. you can't upload it, check that the file name doesn't contain any objectionable wording. I wanted to upload a picture of a BlueTit the other day and it wouldn't allow it as the file name was the same. I had to rename the file to 'bird.jpg'. It's censorship gone mad if you ask me.
Pete11
Seasoned Pro
Fixes: 4
Nice tip sir, and thanks. Thumbs_Up
shutter
Fixes: 47
If you pic file is too large, the quickest way to re-size it, is to use FastImageResizer... puts an icon on the desktop, and you just drag & drop your pics onto it,...#
It will resize them in nanoseconds, and put them in a folder called "Resize" in the same folder as they came from.
(You must set this up first though .... I think there is only about 3 things to set up)..
( Doesn`t (or didn`t) work with Linux )..
http://adionsoft.net/fastimageresize/
Excellent for re-sizing those large pics before emailing them...
MKSlinky
Seasoned Pro
@shutter
Or a simpler way without downloading other tools is to use Windows Paint, resize, crop, flip, rotate, job done. Thumbs_Up
shutter
Fixes: 47
@MKSlinky Actually... once you have downloaded it, and installed it... set your three parameters... it is about 75% faster than opening "paint".. finding the pic. and then doing the crop/resize actions... all you have to do is to drag and drop the file onto the icon on the desktop... no need to open resizer.. ... and the job is done...   resized... saved in a new folder, within the existing original folder,  and renumbered with the new size... you don`t even have to do the "save" or "save as" option..
Simples !
petlew
Download the excellent Fast Image Resizer http://adionsoft.net/fastimageresize/
And set for 800x600 for the resized image, this is acceptable for most general .jpg uploaded images to be published online such as in these forums.
petlew
Oh I see Shutter has already recommended that. I agree with him. I got the hint from him in the first placeSmiley
MKSlinky
Seasoned Pro
@shutter
Don't get me wrong I'm not knocking that program, I'm sure it suits some people very well and certainly takes all the guess work out of things. I do graphic design, freelance and hobbyist so I'm old school in that respect and prefer full control over image manipulation using Photoshop. Wink
shutter
Fixes: 47
Doh !  Roll_eyes
Luzern
Fixes: 9
Sorry for digressing a bit, but that file size limit seems exceptionally generous. @shutter will confirm (0r deny)the truth, but I dis read a good 10" x 8" can come from a 4 megapixel camera
