Peter Nguyen
geewizz
Peter Nguyen
I'm sure some of you will have seen these essays floating around the net before. If not, I'm sure you will welcome it being brought to your attention as many others have over the years.
http://www.mediazine.net/view/essays_by_peter_nguyen
There's another one on Christopher Columbus but the best of the bunch is probably the second on on the linked image.
Re: Peter Nguyen
what a shame.  he's chosen such a stupidly small font, that won't enlarge sufficiently, that he's impossible to read.
geewizz
Re: Peter Nguyen
you could always click on the image to enlarge it. It's a jpeg.
Re: Peter Nguyen
i used ctrl and + a few times but there's a limit.
geewizz
Re: Peter Nguyen
It took me a while to reach it but you're right. There really is a limit.
Re: Peter Nguyen
Yeah, once you get to much more than 300% it gets a little blurry.
