Personal Hints & Tips Thread
Infinity
Seasoned Pro
A useful thread I hope, passing on your own Hints & Tips to others
I suggest, one tip per post...
( I have many ! )
Pills, recording when to take next
At the moment, I am taking two sets of painkillers for a Cat Bite, two of each every 6 hours.
It is so easy to forget when I am next due to take them, so I note, with a Sharpie, on the tablet strips, when 6 hours after I have just taken them, is up.
You will see I sometimes have longer than 6 hours between pills, depending on pain.
But when I take them, I note on the strip when another 6 hours is up.
That way, I don't take too many, before I am due.
Infinity
Seasoned Pro
Re: Personal Hints & Tips Thread
Soaking Labels off bottles
When wanting to soak labels off bottles, to re-use the bottles, I soak the bottle, plastic bottles best with original contents as they are then usually heavier than water, I soak them in a top cut off 2 litre Pepsi, Coke etc bottle.
Usually takes around 3 days, and doesn't tie up a washing up bowl.
Sometimes with just a drop of washing up liquid, to act as a wetting agent.
Works a treat, on every bottle tried so-far.
Infinity
Seasoned Pro
Removing sticky labels off items
WD40 works for me most times.
Infinity
Seasoned Pro
Keeping Shower Glass clean
After much cleaning of a "dirty" water & gel stained glazed shower door, with various cleaning products including wire wool !
To keep it spotless, after each shower, I now squeegee down the Glazed door on the Shower with a £1 Squeegee.
Infinity
Seasoned Pro
When cutting open a plastic bag containing frozen Veg, chips etc, I only cut halfway across the top, helps keep the bag closed when back in the freezer.
Plus, Stationery Foldback clip if necessary
Quote from: PlusComUK
A hair dryer is good for many types.
VileReynard
All Star
Fixes: 11
In what location did you receive the cat bite?  Grin Grin Grin Grin
To get rid of paint smells in a newly decorated room I light a candle for a few hours!
Geoff,
York.
Fixes: 21
But don`t leave it near the turps  Grin
..... or the bums, stiffs and layabouts will find it!  Wink
Geoff,
York.
Glenn
Good tip for soaking labels off...especially for when the labels are completely around the bottle/jar.
Smiley
Infinity
Seasoned Pro
I use this method for removing the labels off Coffee Jars  in Jars I do not like, for ease of opening, and putting onto the Jars from another make I do like to open, being One Twist, rather than two twists with clicks..
Hope that makes sense.  Wink
AndrewLorimer
Quote from: HPsauce
I use an alcohol swab. The swab contains 70% isopropyl alcohol. This is an excellent method for cleaning the residue glue off an item.
Infinity
Seasoned Pro
For my Fridge juice jugs, I drill a small hole away from the spout, on the lid, makes for easier pouring with no splashback .
Similar for milk cartons, 1ltr, a small hole away from the pouring side, made before cutting a small pour spout, made with a skewer, and rotated.
These allow air in, away from the spout.
Infinity
Seasoned Pro
I shake & flip carrier bags, to make a balloon shape, tie the handles, and put this in my kitchen bin, to act as a buffer to keep any smells in.
