Paper shredders
TTman
Seasoned Champion
Paper shredders
Can anyone recommend a home paper shredder please.. the one we have shreds about 5 sheets then jams and has to cool down for 30 mins..Smiley
25 REPLIES 25
Longliner
Fixes: 4
Re: Paper shredders
We have used Fellowes for years without problems (domestic use for personal papers etc probably 10-20 A4 sheets per month). Current machine double-cut so we feed two sheets max at once. In theory you can feed multiple sheets but in practice they jam. Keep the bin empty, surprising how fast it fills up and shreddings cannot fall clear of the cutters. Spray light oil into mechanism now and then, as recommended.
Champnet
Seasoned Champion
Fixes: 7
Re: Paper shredders
We got this one :
Aurora AS1023CD
Paid a bit extra for something decent, been used several times a week for the last seven years....
Fixes: 205
Re: Paper shredders
@TTman
I have a fellows crosscut one. I oil it with shredder oil but it still occasionally jams so if it slows down I open it up and remove the clag. If it's jamming then have you tried stripping, cleaning and oiling it?
Mook
Champion
Re: Paper shredders
I have one of these and it too get some serious use and hasn't failed me since buying it 2016, it also does Credit Cards and CDs / DVDs.
shutter
Fixes: 53
Re: Paper shredders
I have one with the "Woolworths" red trade mark name on it.... bought it a couple of years before woollies went bust !.. (just checked and that was Dec 2008... ! ! ! ! )  . still working !..
use it about once a month on quite a lot of paper ( fills up a black sack & some squashing down).
If you have a local pet shop, or animal rescue centre, you could give the shreddings to them.... might come in handy for pet bedding ????Huh
HelloDuck
Re: Paper shredders
As      Baldrick1      said oil it with shredder oil never knew there was such a product when my shredder started to jam I vacuumed/cleaned the cutters and sprayed it with WD40 let the WD40 evaporate/dry  before using the shredder again
I do this when needed
Do I need to oil my shredder?
All paper shredders need to be oiled because paper dust builds up inside the cutting assembly. As a guide, oil your cross-cut shredder every 1/2 hour of shredding time.
HD
Mayfly
Seasoned Pro
Re: Paper shredders
Ours came from Woolies too. Supposedly can shred up to 10 sheets at once but only ever really works well with 2 sheets max, you can hear it slow down if you try more. As long as I stick to 2 it doesn't jam unless some of that peelable sticky sheet goes through it.
Fixes: 1,246
Re: Paper shredders
I’ve got a Fellowes Powershred 62Mc 10 Sheet Cross Cut.
It’s very good and had no issues after a few years.
shutter
Fixes: 53
Re: Paper shredders
HD
Oil not be doin` that.......  haven`t done it in 14 years  ... and it still works fine...
as mayfly says...it struggles with three sheets....  but there again,... so would I....
Two sheets and a duvet are enough for me.... even if I`m three sheets to the wind  ! CheesyGrinCheesy
idonno
Champion
Fixes: 6
Re: Paper shredders
Dry lubricant (like this) is probably better than oil. Oil (even light machine oil) will just attract dust, clog shredded paper together etc. But then shredders get so little use at home compared to an office environment.
As for @shutter, lord help us! I'll set me main sheets!  🤣
Ever helpful. Grin Sure, I’d love to help you out. Now which way did you come in?
Mayfly
Seasoned Pro
Re: Paper shredders
Dry Lube, sounds like an oxymoron to me. 😂
RobPN
Fixes: 7
Re: Paper shredders
And possibly painful!  Funny
Mayfly
Seasoned Pro
Re: Paper shredders
I wasn't going to go there!
Alex
Fixes: 12
Re: Paper shredders
Yep I would be interested to know.
I've got an old cheapo one, which struggles enough to nuke 1 sheet at a time. Any more and it'll probably have no chance. I could do with a replacement. The one I have will probably burn out and set my house on fire.
I wonder if this one is made in China - I will check. Just checked and as the Churchill dog once said "Oh yes". That explains it - QED and all that.
People at my old company just used to take their stuff to the bigger shredders at work. One that can handle more than one sheet at a time and won't blow up after a yoctosecond.
