Panic
geewizz
Panic
I've got a design presentation to prepare for tonight, I've got a band rehearsal after that and I have to pack a suitcase or two for going south tomorrow. If I hadn't devoted so much tme to this thread then I would stand a chance of completing all tasks successfully. By composing and watching for replies on this thread I will be squeezing the timescale into an unbearably tight gap.
It's right about now that I start to panic and begin the process of tryung to compose myelf enouh to be abnle to typee.
James
Re: Panic
I can ask one of the mods to ban you if you'd like.
Re: Panic
[me=Be3G]used to do that to someone on #Usertools IRC when they kept complaining that they had work to do but evidently weren't doing it.[/me]
Fixes: 18
Re: Panic
Quote from: Jameseh
Might be worth while..... then he would have no egsqus fer bad splling
geewizz
Re: Panic
Thanks for the offer but I like living on the edge. It sharpens the wits.
Fixes: 18
Re: Panic
another spelling mistake..... you missed the "T" from in front of "wits"
nadger
Re: Panic
Quote from: geewizz
I'm trying hard but only half way there  Crazy
geewizz
Re: Panic
Grin Now THAT's funny!
Fixes: 18
Re: Panic
They don`t call me "shutter the nutter " for nothing  Grin Cheesy Grin
geewizz
Re: Panic
Not you. Yours was lame.
Re: Panic
*Passes through and takes a peek*
handbags at 50 paces ladies..
*walks out*
geewizz
Re: Panic
Time's getting far too tight to finish this presentation. I've decided to scrunch up all the drawings and pretend the dog got to them.
Re: Panic
That used to be my favourite excuse at school.
Please sir, the dog chewed my homework up.
Only to end up in detention at lunchtime to do it all  Angry
Re: Panic
Do the whole thing using hand shadows instead!
nadger
Re: Panic
Quote from: rogerloxton
Helps if you have a dog, for starters  Wink
