PN Webmail
PN Webmail
I very rarely look into my webmail, and then only to delete the mostly rubbish that's in it.
However, I login via the Member Centre, do what I have to do in webmail, logout....and then can't get out of that (login page that then shows) page even using the back button unless I close the browser entirely.
Is that how its supposed to be?
2 REPLIES 2
nadger
Re: PN Webmail
I use webmail for most of my daily email.
With the old basic email one can just click on Plusnet in top right hand corner and return to members centre.
As you say, one can't in advanced email so need to start again .
Fixes: 337
Re: PN Webmail
I only use Webmail when away from home as I am now. I just logged in though the Member Centre (using FF29) as OP, then logged out. Clicking on the Back icon several times took me back to the Member Centre, clicking on the big Plus sign above the login fields took me to Plus.net's home page and right-clicking on the Back icon gave a list of previous pages to select.
Are we both talking about https://webmail.plus.net/?
Forum Moderator and Customer
