Ovens
Ovens
Since we moved into our home getting on for 10 years ago, we have had 4 new built-in electric ovens. The house (new build) was supplied with a built-in oven (single type) of nondescript origins. This was quickly replaced with a NEFF, that failed in a big way (caught fire) to be replaced by another NEFF. That has also gone to that great kitchen in the sky, to be supplanted by a Hotpoint (badge engineered Indesit)
My issue with these ovens is that though they are all similar designs -given the type they would have to be- is the way the built-in grill is used, all have been fitted with grill elements in the root of the oven, according to their own instructions the oven door whilst using the grill should be:
Nondescript:  door fully open
Neff:  door completely closed
Hotpoint:    has a partially open position for grill use
Apart from having a sneaky feeling that having the door closed when grilling has led to the faults that has required the replacement of the appliances, does anybody know why different makers recommend the different door positions?
Midnight_Caller
Re: Ovens
Bhy you are having some bad look with Ovens, an Oven should last more than 10 years, I have a gas Oven and it is over 15 years old and still going strong, but it does need a good clean vowe, what I am embarassed to say.
Fixes: 62
Re: Ovens
Neff claim that as their grill is controlled by the oven temperature thermostat having the door open will overheat the top of the oven.
Other manufacturers control the grill by a simple rheostat so the grill element is controlled to give a specified heat output. If the door is closed instead of being open or partly open then the temperature inside the oven could rise to dangerous levels
Re: Ovens
Thank you Oldjim, a wonderfully concise answer.
Midnight Caller, just bad luck really.
jmd
Re: Ovens
It is alright Petlew - I too have had ovens replaced.  In the flat I lived in before to Worksop I had a new kitchen with single fitted Whirlpool oven installed in 1993 - replaced with  Electrolux 1997, that went 2005.  So got an Indesit.
This house had a Whirlpool single oven fitted when I moved in Sept 07, that went in May 09 so now have Hotpoint.
I just wish I had an ordinary oven now not a fitted in one and when this goes I might well see if I can change over!  Hotpoint have just sent me a letter say the 12 mth guarantee finishes in May so do I want to pay £44 for another year's cover!  Nothing like being well in advance but no - I hope this lasts longer than that!!
nadger
Re: Ovens
That's bad luck, Petlew.
We bought a Jackson electric cooker when we bought our first house in 1969 and it made it into this century. Reason we kept it was it had a spit built into top oven.
Bought a Moulinex table top rotisserie oven in France about 10 years ago and that's still working ok and grill is used most days - it's currently warming up some Morrisons steak & ale pies for dinner  Smiley
Re: Ovens
On reflection Oldjim you may have something there.
Both NEFF's had over heating problems with the grill, but both also had oven temperature maintenance problems as well, if they both used the same stat, that would explain much.
