Orange web mail anyway to SAVE an email?
Fixes: 20
I had a query from a friend who uses Orange webmail for his email. He now wants to save an email but nothing appears to do this, the only way I have found searching is to use OE to connect to his mail and download it there, but he isn't very computer literate & it is W8 so nothing is simple. Also I don't know the settings for it to talk him through if we ever got it running/
To complicate things the mail has an embedded video and it doesn't show as an attachment just inside the mail.
NB I haven't seen the issue only phone support.
I had a quick look on gmail and it seems to be the same, no option of saving the email, just view/move it to another folder.
Fixes: 18
Re: Orange web mail anyway to SAVE an email?
Perhaps there is an "Orange" forum, where you can get help from,... if it is SUPPORTED...  that is....  Huh
Fixes: 20
Well I DON'T KNOW shutter, it isn't for me is it? And I would assume it IS SUPPORTED since it is web mail.
Save your snarky comments for those who care about it.
Since this is a GENERIC question (it is the same on Gmail) I thought someone here may have come across it before.
If not then I will leave it since it is:
a) not my problem
b) a M$ based problem ;-)
