Online Banking Security
nadger
HSBC has just advised that I'll be receiving one of these devices
Anyone used this one or one supplied by another bank?
Steve
Seasoned Pro
Re: Online Banking Security
I use one of these John...http://www.craigmurphy.com/blog/?p=634
If life gives you lemons, make lemonade.
James
Yep - I've used something similar through Barclays for the last couple of years.
Bit of a pain, but works fine.
With HSBC, I have one of these.
Fixes: 58
With LloydsTSB I have one of these
Undecided
Customer and Forum Moderator.
I'm with Lloyds TSB but have not been offered one.  Is it a limited trial they are doing Strat?
espresso_mick
I've had one of these for a long time from Smile...
It works well.  A code is generated on the website, you input this into the reader while your card is inserted; this then generates another couple of numbers that you have to input before a transaction can be made.
Steve
Seasoned Pro
Works the same way as mine espresso_mick and I have been using mine for over 2 years at least.
198kHz
Seasoned Pro
Fixes: 9
Same one as Nationwide which I've had for about 18 months-ish.
Seems HSBC have been a bit slow on the uptake.
Papyrus and Comic Sans walk into a bar. The bartender says, "Get out -- we don't serve your type."
Fixes: 168
I've been using Barclays' PinSentry for a long time.
No good when you're out unless you take the machine with you and remember your membership number.
You can still log on without it but, IIRC, you are then limited to what you can do online.
Forum Moderator and Customer
nadger
Thanks for all the replies  Smiley
I've noticed that some devices require a bank card and HSBC one doesn't.
@4C - from journeys post HSBC has had them for a while but I've only been with them for nearly 76 years so well down the list  Wink
Fixes: 15
Quote from: 4C
Yes, I have a Nationwide one. Been using it so long now, I can`t remember when it was first issued to me ! ! ! .
seems you need to get a more up to date bank ! ! !...
gswindale
I don't have any of those with Lloyds TSB.
I do get a phonecall though if I setup a payment to a new person that I haven't used before.
I've also not had any problems with using my banking online (or credit cards) to date unlike others where more sophisticated security processes are in place.
We do use the calculator approach to it all at work though.
Teds31
yes I,m with Barclays and have had the card type for a long time, they seem OK and yiou only need the m/c and the card. Makes me feel safe,hope I am. Huh
Fixes: 58
@artmo and @geofftswin Sorry to mislead Embarrassed
I don't have anything from LloydsTSB hence the lack of a picture.
