One that may even exhaust pierre!
While sitting in nose to tail slow traffic this morning. Although some do -many don't- contain twin exhaust pipes, is there any technical advantage to the flattened oval tail-pipes seen on many -particularly- up-market German cars. Or is it purely a dubious attempt at automotive bling?
nadger
Re: One that may even exhaust pierre!
Amazing how the mind wanders when one is stuck in a traffic jam  Roll eyes
Fixes: 102
Presumably twin exhausts have twin cats...twice the price. Is it a cost saving exercise?
Now you've got me at it Roll eyes
Customer and Forum Moderator.
I do some of my best thinking in traffic jams...
Fixes: 102
Presumably you have one of these. Ok on the motorway but not so good on 'B' roads.
pierre_pierre
Got one that clips over the top of the wheel and a flap drops down, got a cup hole and pen tray, only trouble is, cant drop the flap when anyone is sitting in the seat,might have been OK in the White Van, think thats when I first got it, now it is just taking up space in the garage
Back to the Exhaust, makes you wonder with some of the go faste boxs, all fart and no go
With the bigger cars, i would assume that they are V engines and one exhaust for each bank, been a long time since I looked under the hood.  Also some makers have small bore (The BMC range did) that makes the gas flow faster.  The only work I did on exhaust was measure the CO around the vehicle to make sure it didnt get into the vehicle.  And to gradularly shorten the pipe and measure the floor temperature to make sure your feet didnt get burnt
Quote from: pierre_pierre
Pure bling.  Grin
I've got a 4.2 V8 and it does have twin final exhausts (together, not on opposite sides) but this is only, as far as I can tell, to fit neatly under the bumper.
There is one (big fat) exhaust and one (massive) catalyst, it's just the final box that exits in 2 very short smaller pipes.
But it's a pretty large car with loads of room for "stuff" incluiding all the Quattro gubbins. I imagine some models would fit 2 smaller exhaust systems underneath more easily - at a price.
Fixes: 62
My V6 has twin pipes and twin cats and twin silencers but then the pipes come together for the final major silencer.
I think the reason why there are twin cats is that the v6 is transverse mounted and it wouldn't be practical to have one cat with the feed pipes being of dramatically different lengths
pierre_pierre
this is the tray, name on it is Autopilot, it also has a message, dont use while driving, fat chance of that
Do you like the Mug?
edit
Oh and the seat is right back
Fixes: 10
As I understood it was so that the exhaust gasses could escape quicker (IE less pressure) which allows the engine to pick up RPM faster than a single exhaust.
Basic principle being the faster the emissions get out, the faster the engine can go faster.
pierre_pierre
fast flow up a small pipe reduces the pressure - Bernoulli  theory http://en.wikipedia.org/wiki/Bernoulli%27s_principle
fluid dynamics, Bernoulli's principle states that for an inviscid flow, an increase in the speed of the fluid occurs simultaneously with a decrease in pressure or a decrease in the fluid's potential energy.Bernoulli's principle is named after the Dutch-Swiss mathematician Daniel Bernoulli who published his principle in his book Hydrodynamica in 1738
Fixes: 62
Which actually means that fast flow up a small pipe gives a greater pressure drop than slow flow down a big pipe (with the same total flow)
Basically small diameter pipes, bends, restrictions cause a drop in flow for the same pressure differential.
This is why tuned performance cars use large pipes with as few bends as possible.
However there are two more factors - with all the gubbins stuck at the back of the exhaust nowadays the actual pipe size and configuration is a bit less critical within sensible limits and the other is that if an exhaust pipe has its length/diameter changed from the original design it can cause the flow to reduce by setting up a standing wave as the flow is pulsed not steady.
And no I don't remember enough fluid dynamics to explain the actual theory.
Fixes: 10
Certainly true but then at the same time in order to push those gasses through faster requires energy from the engine resulting in a resistive force against its RPM pickup surely?
The fast flow thing is true, the faster something flows through a pipe the less pressure there will be because there is less particles in the confined space. As OldJim has said though, surely bends in the pipe (which is typical of all exhausts) will create pressure points which slow it all down again. Thats my understanding of it anyway.
In the jam again this morning (see OP) in almost the same place. Observed that lateish Vauxhall's are also sporting the must-have flattened oval tail-pipe, but with a single exhaust pipe inside. But of course, the antecedence of Vauxhall is German (Opel) so perhaps that accounts for it.
What do Kwik Fit do when faced with these articles of Bling I wonder...
Fixes: 18
Quote from: Petlew
I hope you remembered to turn your heater fan off...........   Undecided   . to save you having "forced" co1 emissions in your cab ! !...  Shocked
