One for the photographer. (Nikon)
Mook
Champion
I've been given a Nikon CoolPix P150 however it's not being recognised when I plug it into my Mac (Catalina v10.15.7). I've installed the various software offerings provided by Nikon but none of them (ViewNX-i and Capture NX) recognise that the camera's connected via it's USB cable.
Any thoughts from those in the know?
8 REPLIES 8
Champnet
Seasoned Champion
Fixes: 7
Re: One for the photographer. (Nikon)
I’m a Canon user so not much help, but I wonder why you want to connect it to a computer.
Mook
Champion
To get the pictures off of the Memory Card as it's easier this way and I don't have to remove the tripod lock.
Fixes: 187
@Mook does the camera have any settings for the USB protcol e.g PTP/MTP/MSC ?
This might help explain https://www.nikonimgsupport.com/na/NSG_article?articleNo=000025693&configured=1&lang=en_SG
Mook
Champion
Edit: The camera is in fact a P510 Embarrassed
Fixes: 1,204
My D70 just shows up in Finder, not that that’ll be much help to you
Mook
Champion
I couldn't see anything relating to USB settings in the camera @MisterW but a bit more searching and I found that I can load the images using Launchpad > Other > Image Capture.
As noted above, Image Capture knows the camera's connected but oddly enough the USB storage doesn't appear as mountable volume @dvorak which is odd.
Fixes: 187
Sounds like the Nikon is set for PTP (Picture transfer protocol)  rather than MSC (Mass storage)
Mook
Champion
That makes perfect sense.
