One for the mathematicians:
- General Chat
- One for the mathematicians:
17-08-2018 11:51 AM
I expect most users of Windows have at some time indulged in Microsoft Solitaire, or one of the many other versions. Some (like me) may have actually played using old fashioned playing cards.
And yes, the original MS Solitaire can be installed on W10, much better than the version included in W10. I know, I've been playing it for ages.
But my question for the mathematicians:among you is:
How many combinations of openings - 7 across with the top each of each descending column face up, but before any other cards are played) are there - ?.
Re: One for the mathematicians:
17-08-2018 12:05 PM
Face up or face up + face down ?
Face up = A good Euromillions jackpot win............
17-08-2018 12:12 PM
Yes probably...
All column cards face down, except the first card dealt, and top card of each column, as in standard Solitaire opening deal.
Or to give it its traditional name: the tableau.
17-08-2018 2:47 PM
All together there are Factorial 52 combinations of the game 52! If only the 7 face up cards are considered and the order of the face down cards does not matter then there are 52x51x50x49x48x47x46 combinations. More of a question for a statistician!
17-08-2018 2:55 PM
According to St Stephen of Fry in his temple of QI, the number of combinations and permutations of a shuffled deck of cards is so large, that essentially each each shuffled deck could be considered unique; but a previous answer is correct, and to save you doing the multiplication, there are 674,274,182,400 potential combinations of any 7 cards taken at random from a thoroughly shuffled deck.
17-08-2018 3:52 PM
Perm 7 from 52
I reckon the previous answer (52*51*50*49*48*47*46) needs to be divided by (7*6*5*4*3*2*1)
I don’t mind being corrected.......
17-08-2018 4:28 PM
I assumed that the order of the face up cards is significant as it is in a game of patience. If not the you could divide by 7!
17-08-2018 10:50 PM
FreeCell has become more difficult in Win10. I can still win every game but it usually takes longer than it used to. A few versions ago you could choose a game number, and a colleague tried a negative number. He still got a game but it proved impossible to win.
18-08-2018 12:33 PM
Umm! I suppose then when as happens occasionally, I get a nagging suspicion that I have seen the opening I have before me before...
I probably haven't.
I wonder how well Microsoft shuffles the cards...
18-08-2018 1:31 PM
Quite possibly using the Fisher Yates Algorithm @petlew
18-08-2018 2:27 PM
An interesting read, reminds me of a project we worked on back in the early 90’s.
we found there was no such thing as a random number generator.
No matter how you started the pattern would eventually repeat itself.
so, yes, you’ve probably seen the dealt deck before.......
