One for the guitarists here
I was looking for the tab of a very old instrumental (Wheels by the String-a-longs) and came across this site: http://rock.totaltabs.com/
You can have half a dozen "free" searches, but after that a registration is necessary. But everything is free after that unless you want to donate which you will periodically be asked to do.
Thousands of tabs and chords just for the searching for under four headings.
Worth a serious look.
Fixes: 100
Re: One for the guitarists here
I've used this one for a while now http://www.ultimate-guitar.com/tabs but others are always welcome.
Customer and Forum Moderator.
Yes I've used them as well, but I have found that some of the tabs you really want to get at are not free. No such problems so far with totaltabs.
Fixes: 5
I've been playing Rocksmith instead Smiley
Kelly Dorset
Broadband Service Manager
