On to a Looser!
kmilburn
On to a Looser!
Is it just me that's getting irked by the number of people (here and elsewhere) using 'loose' when they mean 'lose'.
lose    /lo͞oz/
Verb:
  • Be deprived of or cease to have or retain (something): "I've lost my appetite".
  • Cause (someone) to fail to gain or retain (something): "you lost me my appointment at the university".
loose    /lo͞os/
Adjective:
  • Not firmly or tightly fixed in place; detached or able to be detached: "a loose tooth".
Verb:
  • Set free; release: "the hounds have been loosed".
btw.. the title was intentional!
Fixes: 10
Re: On to a Looser!
I wonder if it's because it sounds like loos that they slip the extra o in?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Re: On to a Looser!
It's a very common error on the forums.
RPMozley
Fixes: 5
Re: On to a Looser!
Well you can't fault people like me who have always had spelling problems. A spell checker helps but can't always distinguish similarly spelt words, like your example. What you really need is a definition check too, to go along with the spelling.
That's RPM to you!!
Steve
Seasoned Pro
Re: On to a Looser!
What about ' teh ' Instead of ' The ' really gets on my nerves.
Along with pwn, teh is a standard feature of leetspeak.Originating from the common typo, it has become conventionalized in a variety of contexts. It is often used ironically, and can be used to mock someone's lack of "techie" knowledge or skills, as an insult, or to reinforce a group's elitism;eye dialect. It is frequently used to denote mock ignorance of over-used and over-determined concepts (e.g., "long live teh Patriarchy").
Not just a typo then.
If life gives you lemons, make lemonade.
