Olympics
Re: Olympics
at just under 70 probably been here longer than you Roll_eyes
Re: Olympics
Grin  he knows, you know
Re: Olympics
No the original question was now that we Cant use Weald park because it isnt severe enough the query arose how high is Essex.
Yes you location is correct its on the edge of  High Wood between Duddenhoe End and Langley, Most of the places called Chrishall are in Hertfordshire  482 ft = 146.9 which is the point within Hertfordshire, the Essex point is 139M = 456 Ft
Re: Olympics
And did you know that:
The highest point in Norfolk is in the "cliff top" car park at Cromer
There's a guy cataloguing and visiting the highest point in every English county!  Crazy
Re: Olympics
Quote from: HPsauce
He is going to fail then, unless he as connections or believes in breaking and entering due to the location of the highest point here on the Isle of Wight
Re: Olympics
Just dug out my 1:25000 Map 194,  yes there is a point on the Harcamlow way the other side of the High wood that is 147 m,  although the 1:50 000 Map 154  (1 1/4 in to i mile) only has the 139 M point shown . both points are still just in Essex  So Essex is 8M higher than I thought  Cry
Re: Olympics
Quote from: pierre_pierre
So that's why it feels so cold  Sad
Re: Olympics
Quote from: Spider
why - what is it?
Re: Olympics
St Boniface Down Radar Station above Ventnor
