Ok google..
7up
Fixes: 14
Ok google..
Seems my phone has decided to start spying on me recently.
Twice today it's said to me "if you've just said something, i didn't hear it". Somewhat perplexed I said "ok google" to which the listening screen popped up. This doesn't normally happen unless i press the dot in the middle at the bottom of the screen and drag it upwards. Only then does it start listening.
So anyone else got a phone suddenly start listening full time? I only need to say ok google and it jumps into action.
Where's the tin foil..
8 REPLIES 8
Fixes: 1,179
Re: Ok google..
you can switch it off, but OK google has been around for ages now.
rogadodge
Re: Ok google..
The only time to worry is if Google is your pet name for your wife.... Or girlfriend!
Strat
Fixes: 506
Re: Ok google..
There has been the odd occasion when my PC has responded to something spoken on the TV.
It's quite amusing.
Customer and Forum Moderator. Windows 10 Firefox 88.0.1 (64-bit)
shutter
Fixes: 47
Re: Ok google..
preferably........to save confusion.......  both .... Shocked
7up
Fixes: 14
Re: Ok google..
I'm aware of it having been around for ages, it's been on my phone since i bought it however as mentioned, normally i'd have to swipe the middle icon at the bottom upwards for it to listen.
Now it seems to be listening constantly. How do i turn that off then?
Shep41
Fixes: 4
Re: Ok google..
I might ask my wife if she can change her name to Google. Then at least I know I will get a reply when I ask her something 😂😂😂😂
rongtw
Fixes: 12
Re: Ok google..
@7up  this may help https://www.youtube.com/watch?v=oXnVFj43t8c
Or https://support.google.com/assistant/answer/7394306?hl=en
Jonpe
Fixes: 9
Re: Ok google..
East Germany was way ahead in this respect, every home had to have a telephone socket, although actually getting a phone was a bit like getting a Trabant, i.e. years on a waiting list.  The phone socket, however, contained the microphone through which the Stasi could monitor the citizens.
Perhaps, @7up, you have been specially selected, as Reader's Digest used to say, to take part in a trial by the security services in order to 'improve' their service to the citizens.
