Ok clever cloggs
Ok clever cloggs
Does an incandescent light bulb "waste" electricity when it is lighting a house with thermostat controlled central heating?
The best answer wins a jpg of a 60W bulb incandescent bulb. Full rules and conditions are on the back of my cellar door.
Now Zen, but a +Net residue.
David_W
Re: Ok clever cloggs
Best answer or right answer?  Cool
The answer is no, because if you're using 1 light to light an entire house then it's very energy efficient.
Fixes: 58
It will make a small contribution to heating the house Undecided
Customer and Forum Moderator.
Fixes: 4
That depends on how efficiently the house is insulated.
Fixes: 58
Sorry but I respectfully don't agree.
The contribution will be offered. What the house does with the contribution is another matter. Wink
This is a strange thread......but I like it Smiley
Fixes: 15
Wrong.....  Shocked
The bulb WILL contribute to the heating of the house... Grin
The lack of, or efficiency of, the insulation will make no difference to the heat generated by the light bulb  Cheesy
(had to edit because of strat getting in first ! )
Quote from: AlaricAdair
Is it lighting it from the inside or outside?
pierre_pierre
if you put the bulb underneath the thermostat, it will make the house colder, but save energy
Fixes: 58
Quote from: HPsauce
Good bit of lateral thinking...and a very good point Smiley
"No" if the centreal heating is Electric . "Yes" If it's gas or some other means.
The question was would electrcity be wasted Crazy
I'm surprised no one asked whether it is night or day?
Would this be in relation to ceiling lights or table lamps? since heat rises, you may only be contributing to heating the loft if upstairs ceiling bulbs are left on. Unless you live in a bungalow of course.
Another conundrum for the brain-boxes; take half a glass of hot water, fill it with ice cold water. Does the hot water cool down or the cold water warm up?
Yes  Roll eyes
Fixes: 168
Quote from: Petlew
Heat flows from the warmer to the cooler until both are the same temperature. IIRC  from my A :Lvel physics many years ago this is under the Second Law of Thermodynamics.
Forum Moderator and Customer
