Oh yeah!!
Oh yeah!!
I've had one of those packages arrive, with the terse note; if defective return "unopened" with full details of the fault (paraphrased in case it identifies the manufacturer)
Unfortunately, on opening the product was found to be faulty. I have many qualities but clairvoyance is not one of them!!
Fortunately, it is an Amazon purchase, and they are dealing with it...
1 REPLY
Re: Oh yeah!!
And don't forget that under the Distance Selling Regulations, you have the right to return them within 7 days anyway, whether they are faulty or not. (unless of course the goods are one of the exceptions; manufactured to the customer's specification, food, flowers, magazines etc)  Wink
