Office-in-a-Box Desk and Chair Set £24.99
TORPC
Which one would you choose
My indecisive daughter can not make her mind up & her BF ain't much better either, as he leaves it  all up to her Tongue
http://www.argos.co.uk/static/Product/partNumber/6173931.htm (Black)
http://www.argos.co.uk/static/Product/partNumber/6173924.htm (Clear)
Fixes: 238
Re: Office-in-a-Box Desk and Chair Set £24.99
I wouldn't get either.
I've bought these cheaper desks before and they don't really hold their own.
Forum Moderator and Customer
agree with Mav
something like
http://www.ikea.com/gb/en/catalog/products/20210894/
and something from the Ikea range of desks might be better
Fixes: 20
+1.... If you want to buy rubbish, go to the tip....
at least........... you might find a half decent desk and "soft" comfy "executive" chair.... probably for less money...
TORPC
It was her decision, not mine Wink
Fixes: 238
I tend to go for this type of desk and this type of chair.
TORPC
Unfortunately too wide
The one she chose, yet can not decide on the Clear or Black
Will just fit where she wants it to go, bearing in mind they are only in a bedsit, with no room to (swing a stuffed cuddly toy cat)
If IIRC it worked out approx 2cm under the gap it will be going into Wink
Overall gap approx W 47cm
Linked unit W 45cm
Fixes: 12
If she makes her mind up buy it!;
else
don't buy it;
Simple.  Nothing we can help with.
I have that chair Mav, its uncomfortable and has a unreliable oil ram.  Foam used in the seat lasts no longer than a few months before it becomes unbearably thin.  The back is angled back, which I find gives me backache as there is no lower back support unless you lean back.  Defeats the purpose of a chair to be used sat at table for hours at a time.
Had mine for 3 months then the oil ram started to fail to hold at a set height, constant adjustments every day.  I ended up getting another bit of foam to build up the height of the seat to negate the lack of padding in the seat and partly the height of it with the oil ram at the bottom of its travel.
Simply a seat to avoid.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Fixes: 12
Answering the ops actual question..
Black.
Clear / white can be tarnished. Black tends to deal with bumps and scrapes a bit better. Plus it looks sleek!
Admittedly neither of those appeal to me but I realise (unlike some) that not everyone can afford expensive things.
Mayfly
Not my type of thing but from a house keeping point of view I would go with the clear the black will always show dust.
TORPC
SWMBO & I would help her out if she could find a suitable sized alternative
It is the width that is crucial, the depth or height can be optional
My daughter is currently studying for child care, & her BF is in a low paid job
Fixes: 238
@Gus My chair is very similar to that one although not exactly the same but I'm not sure where I did buy it . I've had it almost four years, I do find it very comfortable and the foam is as good still as when it was bought. The only problem is at the top of the back where it has occasionally rubbed against the wall but that's a user issue and not a design fault.
Fixes: 12
Quote from: Mayfly
Not my type of thing but from a house keeping point of view the clear the black will always show dust.
Most birds are obsessive cleaners so I wouldn't worry about that!
TORPC
your right there, as she has OCD when it comes to cleaning her place, yet when she, lived at home, she was the complete opposite  Shocked
