Numbers
Numbers
I need to print some numbers that are bigger (much bigger) than the 72pt found in most word processors (does anybody call them word processors any more?)
The final size I'm looking for is about <and it doesn't need to be accurate> 4 inches high by 3 inches wide.
So I can print maybe 4 or 6 of them on an A4 page and cut them out and laminate them individually afterwards. It happen they will all be the same number: 5
Ta.
Fixes: 100
Re: Numbers
Overwrite the font size with a size of your choice.
Test and adjust accordingly.
Customer and Forum Moderator.
Re: Numbers
PS. I do have one of those multi-thousands of clip art collections, that has very large numbers, but its so old it won't run on Win7.
I certainly don't want to go to the expense of a new collection just for 6 large numbers.
Re: Numbers
Sorry Strat we must have posted together, thanks I'll try that.
Fixes: 100
Re: Numbers
It works fine in MS Office and Libre Office. I've used the facility myself many times.
Re: Numbers
Brilliant, worked perfectly (300pt was about what I needed)
Thanks Strat
Fixes: 100
Re: Numbers
Happy to hear it Smiley
