Not Very Clever!!
Not Very Clever!!
Bet someone is in trouble for this one! Smiley
Fixes: 154
Re: Not Very Clever!!
Ah it's only about 27 grand over here... so about the budget for the armed forces  Roll eyes
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 60
What did they use invisible paint Grin
No that's silly. You can't paint with invisible paint as you can't tell which parts you have painted Undecided
Customer and Forum Moderator.
Yes you can, just paint the bits you can still see!  Wink
Fixes: 60
But if the paint is invisible Undecided........oh never mind it's all theoretical Wink
Back to Earth Cheesy
Fixes: 154
Do we have to? I was quite enjoying the off planet experience....
If the paint's invisible how do you know if there's any left in the tin Wink Wink
198kHz
Seasoned Pro
Fixes: 9
Has anybody seen my camouflage net? I just put it down for a moment and...
C'mon - it must be here somewhere.  Cheesy
Remeber you are unique - just like everyone else
Another one that got away Grin
That's nothing "our" government has been doing it for years.
Yep, how about this for a waste of money:
http://tinyurl.com/cu86zz
Fixes: 5
Quote from: artmo
You'd see the bottom of the tin if it was empty?
Kelly Dorset
Broadband Service Manager
Fixes: 154
But surely you'd see the bottom of the tin if it was full too?
Invisible paint, as discussed here, makes things invisible.
That doesn't mean that it's invisible itself, expecially when it hasn't dried..... Crazy
Lurker
Like that pink paint that dries white?
