turn on suggestions
Norton DNS - Is anybody using this?
- General Chat
- Norton DNS - Is anybody using this?
25-09-2010 11:04 AM
Is anybody using Norton DNS? It is a DNS server run by Norton. This is a free service and replaces your existing DNS server with a more secure one. All you have to do to use it is to download a client which redirects DNS requests to the Norton one, which blocks any dangerous sites. Have a look at the web site http://nortondns.com/
I have started using it today. You can revert back to your existing DNS Server by uninstalling the downloaded software. Tell me what you think?
Re: Norton DNS - Is anybody using this?
25-09-2010 11:33 AM
This is why I won't use it:
Having read the faq you could have tried it by manually changing your DNS servers in your network settings and without installing the software - if I had been tempted to try it that's the method I would have used.
This is incorrect:
Plusnet's DNS servers are located in the same locations as the gateways you connect through. Generally they must therefore be faster (there's software tools for benchmarking DNS lookups if you want to prove it for yourself).
Here's the tracerts:
Norton (the tracrt doesn't complete)
If you want a backup DNS server for when the Plusnet servers fail use Google (8.8.8.8 and 8.8.4.4). These do not give you sponsored links when you enter a duff URL (Norton have to fund this free service somehow!). You should put these after the Plusnet servers.
Quote Why don't I just get an error when I mistype a domain in the address bar?
Part of the benefit of Norton DNS is that you get guidance versus a useless error page with no information. When you mis-type an address, the Norton DNS service will "guess" what you meant and offer you the right link and/or links that you are likely to be interested in.
This is incorrect:
Quote Does Norton DNS make my web browsing faster?
Everyone will have a different experience, but in general, you can expect that Norton DNS will perform better than your default DNS provider.
C:\Documents and Settings\John>tracert 212.159.13.49
Tracing route to cdns01.plus.net [212.159.13.49]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms dg834 [192.168.0.1]
2 13 ms 12 ms 12 ms lo0-homesurf.pte-ag2.plus.net [195.166.128.73]
3 11 ms 11 ms 12 ms ge0-0-0-505.pte-gw1.plus.net [84.92.4.97]
4 11 ms 12 ms 11 ms te2-2.pcl-gw01.plus.net [212.159.0.185]
5 14 ms 12 ms 12 ms vl63.pcl-lb01.plus.net [212.159.2.252]
6 11 ms 12 ms 12 ms cdns01.plus.net [212.159.13.49]
Trace complete.
C:\Documents and Settings\John>tracert 198.153.192.1
Tracing route to 198.153.192.1 over a maximum of 30 hops
2 14 ms 13 ms 12 ms lo0-homesurf.pte-ag2.plus.net [195.166.128.73]
3 18 ms 16 ms 16 ms ge0-0-0-505.pte-gw2.plus.net [84.92.4.98]
4 16 ms 14 ms 15 ms vl23.thn-gw2.plus.net [212.159.4.20]
5 13 ms 12 ms 12 ms te-3-4.car5.London1.Level3.net [217.163.45.181]
6 12 ms 13 ms 76 ms ae-2-52.edge3.London1.Level3.net [4.69.139.105]
7 * 23 ms 17 ms teleglobe-level3-xe.london1.level3.net [4.68.63.106]
8 13 ms 13 ms 13 ms if-0-1-0-62.mcore3.LDN-London.as6453.net [195.219.83.2]
9 14 ms 16 ms 15 ms if-11-1-3.mse1.LRT-London.as6453.net [195.219.195.22]
10 * * * Request timed out.
jelv (a.k.a Spoon Whittler) Why I have left Plusnet (warning: long post!) Broadband: Andrews & Arnold Home::1 (FTTC 80/20) Line rental: Pulse 8 Home Line Rental (£13/month) Mobile: iD mobile (£4/month) |
25-09-2010 12:59 PM
Treaceroutes to the servers only tells you the latency between you and the servers, not the time it takes for the DNS servers to respond, your test was not a test of DNS at all, if you want to check the speed of DNS then use a tool like this, in general, and especially it seems in the US where alternative DNS services were born, many ISP don't invest money into their DNS and they are slow and prone to outages.
I use OpenDNS because of the management tools and stats they provide combined with the anti virus, anti-malware stuff they do.
25-09-2010 1:26 PM
I think I will be ignoring Norton DNS as it's response times are dreadful !
I just benchmarked together - Two Plusnet DNS servers, Two Google DNS servers, Two OpenDNS servers, and Both Norton DNS servers. and got the following results -
As you can see BOTH Norton DNS servers take around twice as long to respond than any other server.
So don't bother
So don't bother
25-09-2010 1:31 PM
One query even timed out
that very bad for a service marketed as an alternative.
Google also offer a free DNS server http://code.google.com/speed/public-dns/
*Jelv: what tool did you use to run your tests?
25-09-2010 2:01 PM
Quote from: Colin1234 All you have to do to use it is to download a client which redirects DNS requests to the Norton one, which blocks any dangerous sites. You can revert back to your existing DNS Server by uninstalling the downloaded software. Tell me what you think?
Thats one reason I would never try it. Since when have you ever had to install a program to use someone elses DNS? - You can configure it yourself in windows its not hard to do. Anyone who knows what DNS is would know how to do it and as such it seems odd that Norton want you to install their own bit of software which you then have to uninstall to stop using their servers. I call that strange and suspicious. Who knows what else that software is doing.
25-09-2010 2:11 PM
My guess is that the Norton application is there to 'protect' the users PC having the DNS settings altered by yet another shock horror malicious application, to give the uninitiated PC user another layer of false sense of security.
