No Room On Top
No Room On Top
A London bus had its top sliced off today after it hit a tree. A number of people were treated at the scene and two taken to hospital.
Bus Sliced
Luckily there were no really serious casualties.
Re: No Room On Top
Hard to see how that happened.
Tree leaning over a bit, bus right on the kerb edge maybe.
Or mounted the pavement?
Or a dropped drain or pothole making the bus lurch over,
Re: No Room On Top
It was Boris... Cool
Re: No Room On Top
Sound like something out of a Bond film Roll eyes
Fixes: 19
Re: No Room On Top
Looks to me, like the tree that was "leaning over the roadway sightly" was hit by the front left corner of the roof,,,the bus continued on, thus ripping open the top of the bus... there isn`t much metal holding it on to the rest of the bus, if you think about it.... and it wouldn`t take too much energy ( hitting the tree at slow speed) to break most of the uprights in the windows.... the report says that the fire brigade used a winch to remove the roof and bring it down to street level.. (presumably for safety & ease of access )...
Re: No Room On Top
Looks like the bus driver was at fault. Other buses would have used that route earlier in the day.
alanf
Re: No Room On Top
There is a street sign warning of overhanging trees and a height restriction of 2.5m (much less than the height of a double-decker bus). Yet the bus lane runs directly under those trees. An accident waiting to happen. The trees should have been lopped or replaced.
Re: No Room On Top
Quote from: alanf
No, not a bus lane, that's actually parking bays for coaches. I know that area very well and just verified on Google Streetview.
The bus lane starts further up (past the tunnel entrance) where the trees don't overhang.
alanf
Re: No Room On Top
Quote from: HPsauce
Thanks for the correction. I have just rechecked Street View and the short section with the overhanging tree warning comes between two sections of bus lane. I can see how a bus driver unfamiliar with the route could with other distractions not notice that the bus lane had ended. Although there is an "End Of Bus Lane" sign the road surface at the scene of the accident as shown on Street View appears to me to have the red colour of a bus lane.
Re: No Room On Top
So this is really just another "low bridge I forgot I was driving a double decker bus" type accident.
The type of accident a car driver would be done for driving without due care and attention.
Fixes: 19
Re: No Room On Top
As a Public Service Driver...  could he/she be charged with attempted mass murder ... ?  ?  ?
Re: No Room On Top
I guess he won't be driving buses for a while Undecided
Re: No Room On Top
Quote from: alanf
That SV link is some considerable distance North of the actual scene, which was beside the separated tunnel ramp.
Go back onto StreetView and check where the sign is in the BBC picture and the double-separated (3 lanes, 2 islands - nearest also with a railing) carriageway it also shows.
Edit: Now I look again I'm confused. StreetView doesn't match the BBC picture, not quite sure why though.  Undecided
Ah, just worked it out. The bus was travelling South (not North) towards Aldwych and was outside 22 Kingsway (a Kings College building). Still coach parking though, not a bus lane. https://goo.gl/maps/cMzuL
The bus lane finished just before the preceding side road (Sardinia Street).
Fixes: 9
Re: No Room On Top
I cannot agree.
Trees should not be overhanging roads, it's up to the council to ensure they are cut and not a danger to road users.
Re: No Room On Top
But isn't trees overhanging roads intentional in many cases.
The shade protects the road surface from the summer sun.
I believe tree heights and their condition are strictly and regularly monitored.
For the vehicles that use the road in question.
Was that vehicle meant to use that particular road?
