Nitrogen in tyres
- General Chat
- Nitrogen in tyres
Nitrogen in tyres
05-07-2018 3:43 PM
Is this the latest scam or gimmick ?
Having purchased a new tyre the other week there was a notice which said for a extra £3 you could have your tyre filled with Nitrogen rather than air.
The claim is that tyres filled with nitrogen will lose the pressure more slowly ? However the pressure will go down over time so it's unlikely you will return to the tyre depot for a top up.
Re: Nitrogen in tyres
05-07-2018 3:55 PM
It's not particularly new, Costco Wholesale have used it in their tyre bays for many years. I personally wouldn't pay extra for it, if you have tyres fitted properly to non porous wheels with new valves then they need very little topping up anyway. As for the no moisture or more stable pressure with temperature arguments, I suspect the difference for the most of us is insignificant.
05-07-2018 6:10 PM
Kwikfit used to offer this, they now don't !!
(Air is 78% Nitrogen)
05-07-2018 6:19 PM
As Baldrick1 said there is nothing new in using nitrogen in car tyres its been used in aircraft and racing car tyres for years but for different reasons as car tyres eg heat
Air is over 78 percent nitrogen, just under 21 percent oxygen anyway so why pay extra .
When my daughter had new tyres fitted she was advised to pay the extra for the nitrogen fill we could not tell any difference she has not paid extra since
My advice don't your waste money just buy better tyres
Brian A
05-07-2018 7:35 PM
It's a very similar argument for using/not using distilled water to dilute anti-freeze.
05-07-2018 9:04 PM
How about CO2 so we have a ready supply for the next shortage?
05-07-2018 10:50 PM
@Jonpe You`re obviously tyred of this thread, and just trying to inflate the post count !
05-07-2018 11:40 PM - edited 05-07-2018 11:45 PM
You need to tread carefully, I think his post was well balanced.
Though he may have wandered a bit and lost his bearings.
06-07-2018 12:15 AM
Interesting - I'll keep tracking this thread.
ADSL2+ Billion 8800NL
06-07-2018 8:27 AM
Feel under a certain amount of pressure to join in this debate, but also feeling a little flat and deflated at the moment,
06-07-2018 9:28 AM
Our corner shop swears by solids
06-07-2018 9:46 AM
WOW ! ... BIG corner shop.... Groceries, Provisions, Drapery, Clothing, Boots & Shoes.! !
06-07-2018 11:33 AM - edited 06-07-2018 11:33 AM
06-07-2018 12:29 PM
As a matter of interest, aircraft tyres are always filled with nitrogen, apparently its less explosive if a tyre bursts. Didn't help the Paris Concorde though.
06-07-2018 1:33 PM
I used to insist on an inner tube in my tyres...............
