New Shoes Needed
New Shoes Needed
Hi All
Anyone know where I can get some New Shoes from what are wide fitting, all the Shoe shops in Middlesbrough mainly sell standard sizes, I need a size 8 wide fitting I have fluid on my feet, I have been using snickers, and not the Chocolate kind, for the young ones basketball shoes the tipe from the 70's
7 REPLIES 7
Fixes: 40
Re: New Shoes Needed
Here is a link which has wide fitting sizes on the left hand side... ( scroll down the page a bit )...
Also on the home page it says "free delivery"....
http://www.highandmighty.co.uk/shop/footwear/1/_/N-1ytvkxl/products/show.action?hnid=11245407&type=c...
You might also like to search for "Big Man" shops ... there may be one near you somewhere....
M&S shoes are usually available in wide fittings.
Fixes: 62
Try DBShoes as they are the only ones wide enough for my feet http://www.dbshoes.co.uk/
Hi Midnight Caller,
Try http://simplyfeet.co.uk
They supply shoes in Wide and Extra Wide fittings. I have often bought from them and have found them to be excellent.
Smiley
Churches, Cheaneys still come in a variety of fittings.  Standard is an F.  I usually have to go for a G.
Clarks also used to do a variety of fittings, though I haven't worn 'em since I was a kid  Wink
@shutter, thanks I will have a look!
@Petlew, Not in Middlesbrough there is not.
@Oldjim, thanks I will have a look!
@cyrilclark1, thanks I will have a look!
@WTF, Clarks was one of the first shops that I went to, thay don't stok them! in the shop!
Clarkes on-line works ok and the have the full range of fittings.
Now Zen, but a +Net residue.
